SOURCE: Need a belt diagram for a Murray power trac 52'' deck
go to murray website if that dont work go to ebay
SOURCE: How to see if a used snow plow blade will fit my craftsman tractr
Underneath the hood of your tractor is a silver sticker with the sears item number for the correct snowblade. If its a craftsman snowblade it should have a meteal label on it with its model number the 5 numbers after the period need to be the same with what was under your hood to make it the correct blade
SOURCE: i have a 46"lawn tractor murray,when i engage the
I would start by splitting the systems. remove the ground wire that goes to the spark plug coil kill wire.
If the engine runs with the blades on then, the problem is in the chasis or safety switches. if you still have the problem it is the engine. Maybe the engine can not produce enough power to spin the blades.
This could be because of the common deck spindle bearing lock up or the engine being worn out.
After you do the test if you need parts contact a shop like www.arcolawn.com and they can ship you the parts.
Cheers
Joe
