Question about Esselte Dymo LabelWriter DUO for creating perfect, professional labels with the added benefit of being able ... Printer
Label jammed. Blade not cutting label - Esselte Dymo LabelWriter DUO for creating perfect, professional labels with the added benefit of being able ... Printer
A PIECE OF CLOTHING GOT CAUGHT BETWEEN THE PAD AND MOTOR AND JAMMED IT . HOW DO I OPEN THE UNIT UP SO I CAN UNDO THE JAM??
There is an adhesive label on the top of the motor.
There are two very small hex nuts that hold the handle tight against the motor assembly. You can take a sharp single edge razor blade and lift the adhesive label from the motor on either side, the left or the right just far enough to expose the hex nuts. Use a small 9mm socket to loosen the hex nuts enough to slide the cover out. Retighten the hex nuts. Use a strong glue like Gorilla glue to reattach the label.
I sewed some "1-inch" wide elestic straps on each end to the cover to prevent it from sliding....that was over ten years ago and it works great.
Jul 03, 2011 | Jeanie Rub Variable Speed Professional...
We have a dymo labewriter that has a label jammed in the roller. Part of the sticky part is stuck on the roller. Cannot be pulled through. What to do?
LabelWriter Label Jam
  1. Unplug your LabelWriter.
  2. Remove the spool and labels.
  3. Remove the face plate.
    • Note: The face plate is the piece with the DYMO name/logo.
  4. Using the paper release lever on the left side of the printer, move the print head away from the feed mechanism.
  5. Straighten out a paper clip and GENTLY cut away at the label caught in the printer.
  6. Using caution, begin removing the label.
    • Note: We recommend using tweezers to remove the jammed label.
  7. Reinsert the face plate back on the LabelWriter. If you need assistance reinserting the face plate:
https://dymo.custhelp.com/app/answers/detail/a_id/278/session/L2F2LzEvc2lkL2ZVOGZXRmlr
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 28, 2010 | Dymo Office Equipment & Supplies
The cutting bade is getting stuck
Either, the blade has a lot of scraps of paper jammed under it, or the blade is slightly bent (usually caused by people forcing the lid open because the blade remained 'out'). The safe way to get the blade back in is to slide the front panel down and move the little wheel until the traingle appears in the window.  Or it could be a faulty micro switch which turns the motor on and off, the cutting mechanisms are very fiddly though and have some minute screws which are hard to get back in. The microswitches have to be soldered on also. If paper isn't the cause it would seek to get it repaired professionally.
Stephen
Feb 10, 2010 | Epson TM T88II Label Printer
Too much lead on each label. Wasting tape. How do you adjust?
You can't adjust the lead since it is just the tape from the printhead to the cutter, the best way to save is to print several labels without cutting and use scissors to cut them apart after all are done. Otherwise it will advance to cut each time and leave the blank space from the head to the cutter blade.
Feb 05, 2010 | Brother P-Touch 1180 Label Printer
Labels only jam when printing from file
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
May 08, 2009 | HP Color LaserJet 8550dn Printer
Zebra S600 printer
  1. Try just storing your labels in a cool dry place before using them. Peeling labels are usually a sign the glue is poor or weak.
  2. When tearing you labels off, feed them out before tearing them off, then hit the auto-align. See if that helps it.
  3. Try pushing a normal playing card under the metal cutter that tears the labels and pull it up and through the front to bend the blade slightly outward. This will hopefully allow the labels to pass underneath.
Jul 30, 2008 | Zebra Stripe S600 Thermal Label Printer
Does not cut through the tape
Here is what Dymo has to say about this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=68
Here is the text in case the link drops:
Question Why can't I cut the tape after printing a label?
trnsp.gif Answer Every time a label is cut, residue from the label's adhesive remains on the cutter blade. This is a normal occurrence when the LabelMaker is used frequently. It is important to regularly clean the cutter blade in the cassette compartment with either the special brush delivered together with the LabelMaker (located in tape compartment door) or a cotton tip swab and a soft solvent (e.g. alcohol).
If the solution above does not resolve the problem, check for tape path obstructions. If the problem persists, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) number. To obtain an RMA number, scroll to the top of this page and click on the Ask a Question tab. Make sure to include your full name, address, shipping, and contact information.
-Hope this helps
May 19, 2008 | Dymo LetraTAG Thermal Label Printer
DVD label label inner ring or center portion
If the center pops out you should pop it out. This labels are a bad idea in most cases and cause more harm than benefit. They come loose and get jammed. If its important to you buy a Lightscribe burner and DVDS.
Mar 18, 2008 | Televison & Video
Label Maker HELP!! Brother ptouch 1180
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Computers & Internet
Esselte Dymo LabelWriter DUO for creating perfect, professional labels with the added benefit of being able ... Printer Logo
189 people viewed this question
Top Esselte Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Esselte Office Equipment and Supply Expert? Answer questions, earn points and help others
