Question about Acer Aspire 5315 Notebook
Laptop turning off after 5 minutes of uses - Acer Aspire 5315 Notebook
  • 2,567 Answers
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Posted on Nov 10, 2010
After a factory reset my screen is blank
IF IT IS A LAPTOP TAKE OUT THE BATTERY PACK TEMPORARY AND DISCONNECT THE POWER PLUG, WAIT 5 MINUTES. PLUG THE AC BACK IN BUT LEAVE THE LAPTOP BATTERY STILL OUT. MAKE SURE THAT THERE IS NOW CD OR DVD IN THE DRIVE. NOW TRY IT. WAIT AT LEAST 5 MINUTES AFTER YOU TURN IT BACK ON. IF THIS DOES NOT WORK ALSO DISCONNECT YOU INTERNAL BATTERY AND WAIT AGAIN AT LEAST 5 MINUTES THEN TURN IT ON THE ONLY THE AC PLUG IN. GOOD LUCK.
Oct 06, 2014 | Computers & Internet
When i start up the laptop. the screen flashes continouosly for a good 5 minutes
Does it boot up? Are you able to use it after 5 minutes? What does the flashing look like? Is it flashing the boot up posting processes?
Have you tried booting up in Safe Mode and see if it flashes for 5 minutes?
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
May 13, 2012 | Samsung R519-53S Notebook
Laptop shutting down unexpectedly
THE PROCESSOR MUST BE HEATING TOO MUCH. PLACE SOMEHTING UNDER THE LAPTOP SO THAT MORE AIR VENTILATION IS THERE OR USE A LAPTOP COOLER FAN
Jan 11, 2012 | Compaq Presario 700 470024-192 Notebook
How to Reset an fujitso cmos and BIOS Password
This is for Fujitsu Laptops. that does not boot up, Reset and remove the password.
  1. Unplug the power cable and remove the Laptop battery.
  2. Open the back of your laptop where the bios is located using a small philips screw driver.
  3. Remove the Bios Battery for 1 minute and then put it back in and return the back cover of the laptop.
  4. Put back the Laptop battery and plug the power in.
  5. Turn on your computer, sometimes you'll get a black screen even when then power is on.
  6. Let it stay open for 5 minutes.
  7. After 5 mins. Turn off the power and then turn it back on.
  8. Your Laptop should now boot up with the bios password.
Goodluck. Hope my solution will help. Thanks for using Fixya!
Jul 08, 2011 | Computers & Internet
I have one problem in my laptop toshiba C640. i use win xp as my OS. my laptop if i has shutdown this laptop, during 5 or 10 minutes my laptop is turn off. suddenly after 5 or 10 minutes my laptop is turn...
Okay, when you turn the laptop on keep tapping F8, and then goto the option Safe mode. login there and wait to see if this happens there as well. If no, then its a software problem and you can revert to me and I will tell you more about it. If yes then turn your laptop upside down and take a vacuum cleaner and clean the bottom of the laptop.
If you are using the laptop on a bed or sofa, then use it on a table or get a stand for it, so that there is some ventilation space for the processor fan to take out the heat.
If this does not help, then revert.
Thanks. If this was helpful, then kindly rate me.
Nov 07, 2010 | Computers & Internet
I have an NEC Versa L2100 Laptop which is indicating a battery problem where it appears it uses up the battery quickly according to the gauge on the Laptop. Within 10 minutes a fully charged battery is...
Although its not really the complete answer for you.
Go to .. control panel / power options.
You can turn the battery alarm off here, or just change when it starts beeping
Aug 15, 2010 | Computers & Internet
Battery indicator keeps fluctuating to 4hrs to 6hrs back to 4hrs then 8hrs every 5 mins or so i have acer A0532H with windows 7
first of all let me ask how old is the battery, if it`s new-discharge the battery until pc shuts down itself because of low battery, remove the battery , unplug AC charger from laptop, wait for 5 minutes, then hold power button for 5 full seconds, wait another 5 minutes, then put battery and ac charger on , don`t turn on laptop yet, wait until battery indicator shows that battery fully charged, then remove AC charger, and turn on laptop. P.S. you can try this on old battery too, but usually worthless, because old batteries are not recognizable by system currectly ..
Mar 10, 2010 | Acer Aspire One AOA150-1457 Notebook
Laptop Will Not Turn On
first remove batterry from it for 5 minutes ckean its from, dust.
May 08, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
I have a tecra S1 toshiba laptop, when i ON the laptop, the power LED goes ON, the harddisk seems to be operating, but there is not any video on the screen, could it be the mother board?
In order to resolve the issue follow the steps below:
1. Turn off the laptop
2.Remove the battery
3.Remove the power adapter
4.Press and hold the power button on laptop for 1 minute in order to remove static charge.
5.Relese the power button after 1 minute and reinsert the battery and power adapter.
6.Turn the laptop on.
This should solve your problem. If the issue persists follow the steps below:
Turn off the laptop
1. Remove the Hard disk
2. Remove the memory RAM.
3.Wait for 2-3 minutes
4.Reinsert the hard disk and RAM.
5.Turn the laptop ON.
This shpuld resolve the issue. Is the issue persists than it is a clearly indication of mother board malfunction and even could be with display.
Thank you.
Nov 29, 2008 | Computers & Internet
Acer Aspire 5315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
