Question about Air Tools & Compressors
Motor will not turn over even when belt is off. tap the motor with a hammer spin a little then stops
Buy a new motor
Posted on Nov 10, 2010
My Eurika 4D bagless upright will not pick up anything. The belt is not broke but the roller won't spin and there is verry little to no suction. Still makes all the notice but won't roll as easily
You say the belt is not broken and the roller does not spin. Does the motor that spins the belt turn. If the belt does not spin and the little drive motor spins then you will burn the belt out. Try to turn the roller by hand. Could be plugged up with dirt and the roller seized. The little drive motor could be burnt out. Take all hoses and areas out that any dirt could be in. No suction means something is plugged. Even your main suction hose could be plugged.
Mar 15, 2017 | Vacuums
My crosley portable turn table will start but half way into a record it stops spinning; please advise
There is a small motor under the turntable that either uses a belt to turn it or has a rubber tired roller that sets up against it and spins. You will probably be able to find a belt or rubber wheel at a TV repair shop. Some models had an adjustment on them and can be adjusted but more than likely you will need a new belt or rubber tire. The tires looj like a big square :O: Ring
Mar 12, 2014 | Crosley Audio Players & Recorders
I have a 30 year old JVC L A120 turntable. When I pulled it out of my closet, I found the belt had broken and decided to buy a replacement. Before installing the belt, the motor spun and couldn't be...
Clearly a fault with either the motor or the power supply side of it. Try turning the motor spindle with your hands. If you can't get it to move or it's very hard to move, replace the motor.
Aug 25, 2013 | Audio Players & Recorders
My 2006 V Star 1100 Custom out of the blue refused to start right. When I push the starter button you can hear the starter spinning but it does not start. When I tap on the starter with a hammer it kicks...
If the starter does not spin unless you tap it with a plastic hammer then you need new starter brushes. If the starter motor is spinning but the motor is not, then the problem is with the one way clutch that is attached to the fly wheel. The is damage in this case involves two parts the large starter gear and the one way clutch. if the mating surface of the large starter gear is not perfectly smooth then the clutch will not grab it to turn over the motor. Part numbers 2 and 6. http://www.bikebandit.com/houseofmotorcycles/2006-yamaha-xvs11awv/o/m8488#sch531535
Jul 05, 2011 | 2006 Yamaha V Star 1100 Custom
Im trying to put a belt on a hobart 84146
I'll do my best to recall all the steps, I haven't done it in a while. Read instructions fully before starting, as step three may not be necessary, although if performed you'll have much more room for your hands during the remainder of the process.
1. Lay machine on side/back (so that the knife shaft is standing vertically) to access the bottom.
2. Remove bottom cover panel.
3. Remove motor. Two nuts are easy to access, the other two are quite difficult to reach. This step might not be necessary if only changing a belt because you should be able to slip the old belt off and the new one on without completely removing the knife shaft. If the knife shaft must be removed for some reason, the motor must come out to give you room to fit a puller onto the knife shaft (in order to remove the lower knife shaft bearing and lift out the shaft).
4. Take note of the knife shaft pulley. Notice how close to the casting the pulley is. When re-assembling, you'll need to position the pulley at approximately the same location for the black belt to track properly). Loosen two set screws securing pulley onto knife shaft and slide pulley down (don't lose the key for the pulley when you slide the pully down).
5. On the "outside" of the machine, remove the plastic cover where the knife shaft enters the casting.
6. Now visible is a special locknut and special lockwasher (sorry, don't know their names). One of the tabs of the lockwasher is likely bent upward into one of the slots of the locknut. Use a hammer & punch to bend the tab out of the locknut's slot, allowing the nut to turn.
7. Using a hammer and punch, position the punch in one of the slots on the locknut and spin the nut counter-clockwise with sharp blows with the hammer & punch. Have an assistant hold the shaft to offer some resistance to the shaft spinning if you're having difficulty. This may also be easier with the motor and belts still in position, using the motor to partially hold the shaft from rotating while driving the locknut loose.
8. With the locknut removed, spin it back onto the shaft a few threads with the flat side of the nut towards the casting (upside down compared to it's original, installed position). Don't spin it all the way on, you need room to fit a prybar under the flat edge of the nut.
9. Using two prybars, one directly opposite the other, under the now upside-down locknut, pry up evenly on each side of the locknut, and the shaft usually pops out fairly easily.
10. Back on the bottom side of the machine, slip off the belts and replace with new belts and reassemble machine.
11. Be sure to turn the locknut back around to it's proper orientation and be sure to tighten it with a hammer and punch just as during disassembly (special wrenches exist for those nuts, I don't know their name) and bend one of the lockwasher tabs into one of the locknut slots (even if you need to turn the locknut backwards slightly from it's fully tight position).
When everything is reasembled, be sure the flat black belt tracks properly, that is, make sure it doesn't walk off the pulley as the motor runs (just spin the shaft by hand at first to observe if the belt tracks properly.
Good Luck!
May 15, 2010 | Hobart 84145 Food Processor
My front wiper will not work
tap on the wiper motor with a hammer with the key on and wiper on,if it works then replace the wiper motor,which cost about $60.00-$100.00---my ford did that and the magnet inside the motor was broken in little pieces....if the motor doesnt work after tapping on it,even a little, then check for a bad fuse,or wiggle the switch on the end of the signal switch
Dec 30, 2009 | 1998 Ford Expedition
My fan inside run only 5second the ciruits board been change out speed taps move to another tap it run through a cycle then when it come back it only run 5 second i need help ?
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Aug 22, 2009 | Carrier 36KCARMS Air Conditioner
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
LWH0050P Stackable Compact Washer not spinning
sounds like it could be the transmission. Does the tub turn when you turn the pulley in either direction with your hand? And take the belt off see if the motor turns when you close the lid and turn it on without the belt??
Aug 30, 2008 | Washing Machines
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
