Question about InFocus ScreenPlay 4805 Multimedia Projector
---------->> My Infocus Screen Play 4805 -Popped*
My Infocus Screen Play 4805 - Lamp, just Popped on me, and I need to
"Replace it." Can you tell me where I can find the cheapest price for the Lamp and how to "Install it?"
Thanks,
~David
    Scholar:
  • 167 Answers
Hello David,
The best way to find the best price is to do some hunting/research. Google "infocus 4805 lamp"
and wade through to find the best price.
You will find instructions on the lamp replacement procedure in the manual. If you dont have the user manual browse to www.projectorcentral.com and search infocus 4805 and on their spcifications page there is a "user manual" Acrobat PDF icon.
click on the icon to open the manual in pdf format
Take Care!
Posted on Dec 29, 2009
I recently had my lamp go out for the Infocus SP 4805 projector. When I replaced the lamp, the projection/imapges had discoloration in a couple of spots on the screen. not completely black, but discolored....
If you have not already found out, your problem may be a Light Tunnel Failure. It is common and can be corrected DIY. Replacement part is nearly non-existent and manufacturer repair is expensive.
For additional info go to www.avsforum.com and search for "4805 Light Tunnel". You will find threads about the problem as well as fixes. I also posted a DIY replacement option as well:
www.avsforum.com/avs-vb/showthread.php?t=1304694
Sep 13, 2010 | InFocus ScreenPlay 4805 Multimedia...
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    It has a shadow on half the screen
    the light tunnel has collapsed. you can get the part from an infocus service center and do it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
    Jan 18, 2010 | InFocus ScreenPlay 4805 Multimedia...
    When unit was turned off last night it "popped". Now it does not come on and the power light flashes at a rate of 1 flasher per second.
    the lamp blew. take it out and see if there is shattered glass inside. if there is, replace the lamp and blow the dust out of the projector. the dust keeps in the heat that the projector is trying to expel. the lamp probably overheated and shattered. otherwise, it was at the end of it's life (usually 3000 hours).
    Jan 04, 2010 | InFocus ScreenPlay 4805 Multimedia...
    How do i find out if i need a new lamp for my infocus 4805. when i turn it on the fan blows for a cpl secs and the green light blinks a few times, but i dont get anything saying the lampis out
    when you power it on, do you hear a high-pitched whir? if not, you need to replace the colorwheel. it's also the colorwheel if you hear a buzzing instead. if the colorwheel does not spin, the lamp won't come on. if the colorwheel is ok, check the lamp. is the screen on the side of the lamp clogged with dust? is the inside of the lamp bulging, spotted, or foggy? if so, replace the lamp and clean out your projector with canned air. dust blocks air flow and keeps in the heat. this shortens the life of your lamp and projector. if you do need the colorwheel replaced, you could get the part from an infocus service center and do it yourself, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
    Dec 27, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Infocus 4805 Lamp will not ignite after new bulb and reset.
    it there is no high-pitched squeal when it starts up, the colorwheel needs replacing. the lamp won't light without it. the part is under $50, but installation is quite involved.
    Apr 16, 2009 | InFocus ScreenPlay 4805 Multimedia...
    My Infocus 4805 suddenly blackout
    First check what is the lamp you using please use lamps recomended by SONY only. That lamps might run up to 2000 hours so.......try checking your lamps and let me know.
    Jan 26, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Projector Problems
    Sounds like the fuse popped. t5a=5 amps 250v=250 volts So you will need a fast-acting 5 amp 250 volt fuse
    Mar 14, 2007 | InFocus ScreenPlay 4805 Multimedia...
    InFocus ScreenPlay 4805 Multimedia Projector Logo
    175 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
