I purchased both from HSN several months ago. Printer works great, faxes great. But today I tried for the first time to scan a pic from the printer to the computer. Printer says can't find scan application list from computer. The printer shows the pic in the 2" X 1 1/2 " window, but won't sent it to the computer. The Lexmark book says to click on the Productivity Icon on the computer, but there is none. I searched the computer for that program and it doesn't find it. Help please!!!!!!
SOURCE: Windows has encountered a hard disk drive problem
You can get a 1 terabyte sata hard drive from Newegg for 99 bucks. For that price why play with a failing drive. If you get one I will help you set it up with out the Gateway ****. http://www.newegg.com/Product/Product.aspx?Item=N82E16822136151
SOURCE: At about 3:00 am on thursdays, Windows XP closes
Sounds like the computer is coming from sleep, standby or hibernation mode. Go to the power settings in the control panel, and disable all of these options. Disable your screen saver as well. Leave the machine on for a day and see if it happens again after this. Post your findings, please...
SOURCE: My computer mysteriously now does not show my
Well your second hard drive did go belly up so what you need to do is get a new hard drive because from what you have explained to me it's fried. Now one other way that you can try and get it back on there is to boot up your computer but before it goes to the windows screen go into bios and select boot options and make sure that it's checked as a secondary if it already is then you need to go get a new hard drive which runs about $25.00.
SOURCE: My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Testimonial: "If I keep swapping parts to isolate the problem, then I have to buy these three parts, that could be not worth it. Should I just buy a new PC?"
SOURCE: I installed windows 7 with a clean install.
change your boot to cdrom when you do a clean install remove all partitions and recreate one partition wich will be c: that should work
Hi Cable4Fun, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Which vista 32 bit or 64 bit ?
Did you install the lexmark x8350 driver or did windows fid a driver for you ?
The productivity suite might be included in the driver from lexmark ?
suggest if you have not done this already to download the driver from lexmark and then run the install of the driver and see if it installs the productivity suite software. http://support.lexmark.com/index?page=dr...
put Lexmark X8350 as product name
