Question about Ryobi Three Trimmer Combo
SS30 Trimmer dies when you squeeze the throttle.
  • 11,896 Answers
First make sure it is warmed up first. A good way of letting it warm up is to feather the throttle for a while until you can hold the throttle all the way down and let it run full speed for 1 minute. Then try a regular use. If it still acts the same, then I suggest removing the carb and completely clean it out.
Posted on Nov 10, 2010
Get fresh petrol..it will have deteriorated over the winter
Posted on Jul 31, 2011
How do I remove the carburaetor locks on Ryobi ss30 seedeater I am a beginner lady learning to fix my own stuff
Remove carb mounting bolts. Carb obsolete not available. This may help: http://www.ereplacementparts.com/ryobi-ss30-ry30002a-string-trimmer-parts-c-7931_15633_15652.html
Dec 22, 2015 | Ryobi Garden
New Ryobi trimmer putters out at full throttle
Absolutely it can. Weight can slow it down, Friction can slow it down,. There are many things that will do exactly what you are talking but the #1 thing would be a Gummed up Carburator. EVERYONE is having the same problems right now.
Apr 07, 2013 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
My SS30 trimmer will not idle or run at high speed. I usually have to pump the throttle to keep it running. I have replaced the spark plug.
The majority of problems with these machines is fuel related and so is yours. IT sounds like the carburetor is not being responsive which indicated it may need a rebuild or diaghram kit installed. This usually cures a lot of the ills but not always . They are not too expensive and not real hard to install.
Aug 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Aug 18, 2009 | Ryobi Garden
I have a poulan pro trimmer, it wont stay running
First of all, YES. boggs is a word in my dictionary. Remove the muffler and carefully take it apart. Pay close attention as to how it comes apart because it is vary important it goes back the same way. you will probable find that it is clogged. If it is then remove the debree. If it isn't then you will have to adjust the fuel mixture screw. First start the trimmer, then let it run for a few minutes to warm up, then gently turn the screw a little bit at a time counter clockwise first, squeezing the throttle inbetween adjustments . If it starts to take off then fine tune it untile your happy. If it boggs worse then turn it clockwise.
But first check the muffler.
Good luck
Aug 05, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
The weedwacker dies when I squeeze the throttle trigger
You need to clean the carburetor. Remove and disassemble carb. Use a den Tek Brush, (used to clean between teeth), to clean the small portals in carb. Use a carb. cleaner while cleaning. Make sure the small screen in carb. is free of debris. The smallest of paticles can cause the carb. not to run right. Reassemble the carb. and try starting. If there is no change, then you will need to buy a carb. kit for your trimmer. Replace all appropriateparts: gaskets, diaphragm, needle valve, and the small screen.
Jim
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Ryobi SS30 trimmer starts fine and runs at when in full choke position to about half choke position. But when I put the choke lever to the full run position, it stalls out. Ryobi ss30 same problem of...
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
May 29, 2009 | Ryobi Garden
Homelite trimmer dies every time I squeeze the handle
remove the muffler,disassemble it,you will find a spark arrester screen in it.it is either clogged up with carbon or partially clogged,clean all carbon off,reassemble and try again
May 28, 2009 | Homelite Mighty Lite Lawn Trimmer
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Ryobi Three Trimmer Combo  Logo
992 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Gene Tuck
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
