Question about LG Televison & Video
32 in LG, about two years old, won't turn on. Have unplugged everything. Little red light blinking below screen near infared receptor.
  • 11,361 Answers
The 5vdc standby power suppy is working but not the rest.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
By the way, what is the model number of the TV?
Posted on Nov 11, 2010
  • LG Master
  • 8,457 Answers
The tv have a dead power supply board.That the board,where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Nov 10, 2010
I have a 32 inch Samsung TV that is only two years old. When you press the power button, it sounds like it it turning on and the red light comes on but the screen is black and there is no sound.
Main board is bad since it works with both video and audio. Ur backlights are ok so that omits the inverter board. And the T con board is for video only - since you have hassles with audio and video that leaves the main board. Do not think it is the power supply since your inverter board is powering up the back lights.
Nov 11, 2015 | Samsung UN39FH5000FXZA - 39in 1080p 240...
LG 32LH30 screen won't power up. Red light at bottom glows hi to low, but no picture. Unplugged and waited overnight, plugged in again, still no picture.
There is a way to tell if you have a bad board, or a bad panel.
1. Make the room dark and turn on the TV. Can you see it light up? If so, does it stay lit or turn right back off?
2. If the panel lights, but you have no picture, I would suspect the T-con. Some units now have the T-con incorporated with the main board, so you will need to check.
3. If you never get any light at all, then I would suspect the power supply.
4. If you only get light for a second or two, then you have a bad panel.
Apr 10, 2012 | LG 32LH30 32 in. LCD HDTV
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Power light blinks red, TV doesn't turn on
if you are not technical i sugest you have this checked out by a professional most probably a fuse has gone from iside or your driver board has gone down. The blinking should be normal after you have turneds it off because some capacitors will be discharging.
Aug 23, 2007 | LG 32LX1D 32 in. LCD Television
Televison & Video Logo
67 people viewed this question
