Question about Mitsubishi WS-65809 65" Rear Projection Television
I need a replacement tremble speaker for this tv. The # on the back of the speaker is: 480P039-1 10 watt 8C. Can you help me?
  • Mitsubishi Master
  • 5,138 Answers
Call Mats Electronics 1-800-628-1118 You can go to their website and order Free Catalog of all the things they sell
Posted on Nov 10, 2010
Can I replace the speakers on this system? Speakers are too large for space & want to replace with another brand.
make sure impedance is the same so 6 ohms and the power rating of speakers is no less than 200 watts peak rms.And bare wire ports on back of speaker.
The power rating is so the speakers can handle the maximum power delivered by stereo amplifier without burning out speakers coils.
Jan 23, 2016 | RCA Audio Players & Recorders
Trembling and vertical overlay image : how to fix it ?
Main power supply regulator board fault. DC voltage output from it is abnormal. Contact any service technician.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Jul 30, 2014 | Samsung UA-32D4000 MULTI SYSTEM LED TV...
I have a caliber 2007 with stock stereo and one spekear need to be replace but i opened it and it look to small on wats i have a 50w 4oms speaker and the stok speasker is size 15wats 4 oms can i still...
Yes , you can replace the 15 watt speaker with the 50 watt speaker. The impedance of both speakers (4ohms) is the same , so that's a match. Actually, the 50 watt speaker may sound a bit better at higher volume, because it will not distort as much as the 15 watt speaker. Hope this helps...
Jul 17, 2009 | Car Audio & Video
New Radio too powerful for 15 Watt speakers?
Hello mike_mccuske,
The OEM speakers will still work OK with your new Pioneer. Just don't turn it up too loud. Of course you'll get improved sound if you replace the speakers. Your Pioneer's RMS power is 14 watts, and the peak (maximum) power is 50 watts. The door speakers in a 2000 Honda Civic are 6.5" and you can get a set of Pioneer speakers, the TS-G1642R's, from Crutchfield for less than $50. Their RMS power range is 2-30 watts and they can handle a peak power of up to 180 watts.
Hope this helps.
May 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
My television
depending on what kind of TV it Is, If Its HD or like the Flat Kind My Solution wount help, because i've never took one apart before. if its a big bulcky kind take the screws off an an take the back cover off, but be sure to be carfull with the lil glass bulb located on the back of the screen it holds a chemical in it, an tv wount work, once taken off you could either replace the blown speaker, or just run a speaker wire from the wire connected to the blown speaker an run it out the vents on the TV an find any speaker not with too many watts, ive hooked up 2 150 watt speakers to mine an it worked fine i hade the same prob. another thing, if your warrenty is stil good you could get a replacment
Oct 18, 2008 | Scott SQX-900F Main / Stereo Speaker
Toshiba 50h13 image trembling
something is not in tolerance in the deflection circuits if it is an up and down tremble its vertical deflection related and if its shakey from side to side its horizontal deflection. You will most likely need a skilled tech for this type of repair.
Apr 06, 2008 | Toshiba 50H13 50" Rear Projection...
I have picture but no sound
go into the audio menue to turn speakers back on
Dec 27, 2007 | JVC AV-56WP30 56" Rear Projection...
Help...I need a replacement part for my Mintek Television speaker!
I'd open up the unit and physically check the speaker. Try to find a driver that most closely matches yours.
For starters you might check:
http://simplyspeakers.com/14replacements.htm
Mike
Dec 06, 2007 | Mintek DTV-173 17 in. TV/DVD Combo
Static kinda sound
hi sounds like a earthing problem in the reciver or problem in the speakers try rotaiting the speakers back to front front to back left to right ETC.. good luck
Dec 31, 2005 | RCA RT2500 System
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
