Question about Sport & Outdoor - Others
I have a model 77 winchester. I need three parts, correction six parts. Trigger lock trigger lock spring and trigger lock retaining spring. Additionally The three bolt/ screws to hold the trigger guard and THE barrel lug
SOURCE: winchester model 100 semi-auto 308 cal. how to disassemble?
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
WARNING DO NOT SHOOT YOUR WINCHESTER MODEL 100 RIFLE OR CARBINE. Repair and replacement.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
USA
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
pin
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
Posted on May 20, 2009
  • 302 Answers
SOURCE: Badly need the front and rear trigger guard
did you try www.gunpartscorp.com ?
Posted on Dec 02, 2009
jyackle5
  • 8197 Answers
SOURCE: need repair manual and parts
You can get the repair manual and parts on link below.
http://www.crosman.com/airguns/service/manuals/crosman-pistols
Posted on Dec 22, 2009
steve_e_uk
  • 1675 Answers
SOURCE: remington airmaster 77
http://www.crosman.com/pdf/manuals/RAM77-EVP.pdf go to this link it will give you an exploded view of the whole of the rifle...hope this helps
Posted on Nov 04, 2010
  • 111 Answers
SOURCE: my A5 just rapid fires when the trigger is pulled
Make sure your battery is new. It doesn't take a lot of voltage drop to affect performance.
Make sure your marker is clean, and properly lubed with a quality oil make for paintball.
Make sure your board connections are secure. You can change modes on the e-trigger yes? Go through them and fire a few times in each to ensure it's changing.
Make sure you have a full tank of air while your testing to make sure this isn't a problem as well, or causing your issues.
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
Where can I get a winchester low wall diagram
Browning made a repo of the low wall and should have a parts diagram.
A set trigger 'c ocks' a smaller 'hammer' that thumps the sear. It works by the inertia of the trigger which acts as a hammer.
Sep 22, 2014 | Winchester Model 1885 Low Wall .243 24...
Do they make a trigger kit for a pk380?
Not sure what you mean by "trigger kit", but if you mean how to reduce the lbs of trigger pull, several companies off spring kits.
Here's an example:
http://www.midwayusa.com/Product/177318/wolff-hammer-spring-pack-walther-ppk-s-reduced-power
Jul 01, 2014 | Browning Bar Mark Ii Safari .243...
Winchester model 1200 action stuck open
You have to make sure the hammer on the trigger group is cocked and then you have to make sure the slide arms are in the cutouts on the bottom of the bolt assembly.
You assemble the trigger group to the receiver by carefully working the front end of the trigger group into the slots at the front end of the receiver. Then gently push the rear end of the trigger group down into position. This should go in easy if everything is lined up--don't force it.
Then install the trigger guard pin from right to left until its flush with the receiver.
I took all the above from the pdf manual I have for the model 1200 that I found online. The pictures would help (page three). I'm looking for a link to the manual and will post it when I find it.
Here, its on page three of the manual: http://gunmanuals.net/Manuals/winchester_1200.pdf
Sep 28, 2013 | Sport & Outdoor - Others
I need to adjust my trigger pull on a Ruger Model 77 rifle.
If you'll look up into the trigger assembly inside the trigger guard you'll see a set screw. I've got one of those old Rugers and supposedly that set screw is for adjusting trigger pull wt.
Nov 07, 2012 | Refrigerators
Hold down lock does lock i think there is a spring missing
The trigger lock spring (just one does both functions) is quite a challenge. It uses an almost invisible slot in the trigger for the small end and the long leg pushes upwards on the other part that is depressed by the palm of your hand. I had to try three times to get it to assemble right on my small Jonsered chainsaw. The two halves of the handle should go together by finger pressure when it is in there right.
Mar 28, 2011 | Garden
Removing bolt from a winchester model 67
Pull stock off your model 67 win. The trigger stays in the stock . Lift up on the barrel and action while pulling it toward the end of the stock. To separate them. Next open the bolt , then reach under the action grasp the arched piece of spring steel . Pull down gently on the spring steel retainer while pulling back on the bolt. You can also remove the ejector assembly in the same manner pulling down on it. Assemble in reverse order.
Mar 31, 2010 | Winchester (026196062448) (20 - 60x70 mm)
Describe your How do u put a trigger an a mag 77 skill saw Problem
There are a few screws on the handle, remove them and it comes apart in 2 pieces, the trigger assembly will then come out. Disconnect the trigger from the wires and replace. Any Bosch service depot should keep this part in stock.
Cheers,
Kevin
Mar 23, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Winchester model 88. with the trigger assembly
Less Than Perfect
The Model 88 had its faults. The trigger moves with the lever and the resulting linkage to the sear results in a rather spongy, creepy trigger break. If you want to see your gunsmith turn pale, waltz into the shop with an M88 and ask for a crisp three-pound trigger.
If you already have taken the gun apart, don't be afraid to hone the parts on a stone , keep them flat, you don't want anything rounded off. Especially the sear. I found that quote up top from a winchester sight,
Feb 22, 2010 | Optics
Part fell out of gun dont know where it goes
is it the carrier support spring or the trigger spring?
go to www.winchester.com look for owners manual for model 94 come times the site dont work well.you may have to call them and ask for a schematic parts break down they will send it to you or e-mail it.
Oct 28, 2009 | Sport & Outdoor - Others
Hoover SteamVac
I'm not sure what your referring too, but Here is how it works. The trigger is snapped into two "rocker retainers" in the handle. when you pull on the trigger, it rocks and pushes on a rod that goes down to another shorter rod and that one pushes on the valve that releases the solution. A common problem was that the "rocker retainers" would break off and the trigger would not push on the first rod so the machine would not release solution. You will have to replace the handle half (called a trigger guard). The trigger itself has two plastic "springs" molded into it. This is all one piece with the trigger and they don't usually break. Also, when you remove and replace the handle, you have to pull the trigger to re-engage the two rods togeather or the machine will constantly spray solution. I hope this helps.
Jan 12, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
