Question about Legacy LA2259 Car Audio Amplifier
Legacy 4000w amp acting funny with subs
I have a legacy rebel 4000w and i am connecting *** with my 3 12' pioneer premier speakers, but for some reason after it is all hooked up it cuts on for two seconds and then blows a fuse.. i am seeking help 2 fix my problem cause i have no money for a new sound system please let me know if u know wht to do or if am running the wires wrong
  • Anonymous May 07, 2009
    i coonect five subs and it just cut off for a second
  • Dave DeGain
    Dave DeGain May 11, 2010
    The legacy amp, it is a 2 chanel bridgable amp. But what is the impeadance rating for it in bridged mode? If you have all 3 subs in parallel and bridged, you have a very low impeadance, under 2 ohms. That is almost like a dead short to the amp. If all of your wiring is correct and the right guage wire is being used, the most likely problem is the speaker hook up.
    Try putting it in stereo mode and connect just one speaker per channel and see if it turns on. If so, you just found your problem. Improper speaker connections. The legacy amp is a very low cost amp and claiims to be 4000 watts. That is a little too good to be true, don't you think? Remember that you get what you pay for, and car amplifiers are no exception. Not all amplifiers are rated properly. Play it safe with this one and it might last you for a while. But try and push the most power out of it that you can and it will burn up on you. The speaker impeadance that you connect to the amp is very, very, very important.
    By connecting it in stereo mode and using one speaker per channel, you will have a 4 ohm load on each channel and it will get alot of power out of it. I would never try to push this particular amp to the extreme, you will not be happy with the end result.
    President:
  • 624 Answers
Do you still need help wit this amp? If so, please provide the needed information. If not, just ignore this post.
Posted on Oct 16, 2008
  • 29 Answers
You either have a short, or the speakers are too powerfull for it, or the most likely problem is that your fuse is like 15 amps, but the amp is like 20 amps, so check the amps and if they are near 13 or higher, put in a higher rated fuse. :)
Posted on Jun 18, 2008
I have 2 solo baric l7 duel 4ohm subs and a legacy la-2499 amp.What is the best way to wire it up?
Unfortunately, the amp is only 2 ohm stable, so the best option is to connect each subs voice coils in parallel (2 ohms) and connect the subs in series (4 ohms).
Oct 06, 2015 | Legacy Car Audio & Video
I HAVE A 1200 Watt Legacy Rebel amp and when I power it on the lights turn on but no sound comes out. Please give any help
You need to make sure that the subwoofer leads are connected correctly. It may be that the subs aren't connected properly. That would cause the amp to turn on without any sound coming out.
Mar 06, 2011 | Legacy LA2259 Car Audio Amplifier
How to wire the Pioneer Premier 12in. dual 2 ohm voice coil. 1000 watt rms 3500 watt peak, and I have a 1000watt JL audio 2 channell amp, they are both stable at 1 ohm. I wired them parrallel, and it blew...
If you have two subs to connect, place the speakers next to each other face down, you will notice that the connection points run in sequence +- and +-. Now connect the - (negative) from the one speaker, to the + (positive) of the other speaker. Now connect the open + from the one speaker and the open - from the other speaker to your amp.
If you have only one speaker it should be bridgeson your amp.
Your amp should have a bridging indication. On the connection points of each channel on the the amp, you should see a mark pointing to the first - and the last +. That will be your bridge
May 09, 2010 | Pioneer TS-W3004SPL Premier 12" SPL...
How can i connect 2 12''s pioneer premier too an jl audio amp n make the bass loud???
Hello m1k377060,
Having your subs in well-designed and constructed enclosures will make as much or more difference in their output than how you connect them to an amp.
The TS-SW1241D's are single voice coil 4 ohm shallow subwoofers that are rated for 350 watts RMS. For maximum loudness, your JL amp needs to be 2 ohm stable and capable of delivering 700 watts RMS into that impedance. Wire the subs in parallel for a 2 ohm load and maximum power from the amp.
Hope this helps.
Oct 09, 2009 | Pioneer Premier® TS-SW1241D Car Subwoofer
Wiring issues
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
May 30, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
The fuse from the amp to the battery keeps burning
maybe it cannot accomodate too much power running on it...too much current, try another fuse with higher ampere rates
Jan 14, 2009 | Nitro BMW-486 Car Audio Amplifier
Premier sub used to work great ... now nothing
Did you check to make sure that you didn't blow a channel in the amp? Another thing to check would be the connection on the inside of your box, maybe there is just a wire loose.
Dec 19, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Engine noise from Legacy 4000W 2 channel amp
Hi Justin,
Send me the specs. on the speaker ( voice coil impedance), amp, power wire size, and box
As for engine noise ( alternator whine) 99.9 times out of a hundred it's caused by what's called a ground loop, That will take a little trouble shooting on your part. It's no big deal. It will be a step by step process. All you need is two alligator clips or a old RCA cable.and a couple feet of wire. I'll try to get to it this evening,
Oh, and you will have to pull the head unit out of the dash... P
Jun 11, 2008 | Car Audio & Video
Wiring speakers to amp.
Hi mate you need to leave a bit more detail on the amp so I can help, what are the outputs saying?
Feb 18, 2008 | Pioneer TS-W125C Car Subwoofer
Amps
It comes down to Amperage and RMS, your best bet is to go in and talk to a salesman at a stereo shop. That way he can decide on what sort of power you want and how you wanna use the subs. But 1000amp AMP is probably a good start 4 channel of course. Alpine or SOny make some kick a$$ AMPS
Feb 17, 2008 | Pioneer TS-W3004SPL Premier 12" SPL...
Legacy LA2259 Car Audio Amplifier Logo
753 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
isaac johny
isaac johny
xxxxxx xxx
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
