Back to:
Tags:
Jenn-Air JCD2389G Side by Side Refrigerator
Jenn Air JRSD209T
posted by polaris6 on Jun 17, 2008
I just moved into this house and it has a Jenn Air209T side-by-side refrig/freezer with a water dispenser and ice maker...neither of which work.
It doesn't make ice and it doesn't dispense water.
I checked to see if water was getting to the valves and...yes it was...very weakly. I check the water pressure at the site where the refrig water line is tapped into the main cold water line and still not a lot of pressure.
How much pressure should there be at the tap site/refrig valve sites? I have installed a few of these devices in other refrigs and the pressure is quite high.
Does there need to be hig pressure in order for the ice cube maker to work? Will this low pressure 'discourage' the ice cube making process?
The ice cube making chamber does get cold and when I press the 'ice cube button it sould like it want to dispense ice, but none has been made.
Thanks for your help.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 15, 2008
Not Rated (0)
klbrisby
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This is just anecdotal here, but one repair guy who came out and thawed a frozen line into the icemaker told us the fridge required near-full line pressure 90- or 70- or whatever that is, in order for the ice maker to work. This was a licensed repair guy. We were feeding it with an RO, which only pumped it in at 17 or 20 psi (or whatever the unit is) which he informed us was inadequate. However, after he thawed things out and we changed out the inline carbon filter in the fridge, everything was hunky dory for a couple of years. About a year back, the icemaking stopped, and changing out the carbon filters in the fridge AND in the RO system did the trick.
Now we have a different problem. Things aren't getting or staying cold, especially the fridge. I opened the housing in the back of the fridge, defrosted the extensive ice accumulated around the refridgerant coils, and everything ran great for a couple of days. Now we're back in the global warming pattern: steadily rising temperatures and thawing. I'm not feeling too happy about Jenn-Air these days.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Jenn Air JRSD209T:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
My side by side is really hot to the touch between the...
My Jenn Air refrig model # JCD2389GES is not cooling on...
It appears that there is a latch that doesn't catch...
the refridgerator has rotating handles to raise and lower...
my jenn air refrigrator stoped mamikng ice
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
