Question about D-Link AirPlus DI-614+ Wireless Router
The Wireless router in our house is resetting itself every few minutes disconnecting all of our devices. I've tried manual resets and recently had a repairman out here to adress the problem. He claimed to fix it but the system is still on the fritz. I have no idea where to even start so any and all suggestions are appriciated.
    Guru:
  • 610 Answers
Home wireless networks based on the 802.11b or 802.11g standards transmit their signal in a narrow radio frequency range of 2.4 GHz. Various other electronic devices in a home, such as cordless phones, garage door openers, baby monitors, and microwave ovens, may use this same frequency range. Any such device can interfere with a Wi-FI home network, slowing down its performance and potentially breaking network connections.
The 2.4 GHz Wi-Fi signal range is divided into a number of smaller bands or "channels," similar to television channels.Many wireless products ship with a default Wi-Fi channel of 6. If encountering interference from other devices within the home, consider changing the channel up or down to avoid it. Some Wi-Fi channel numbers overlap with each other. Channel 1 uses the lowest frequency band and each subsequent channel increases the frequency slightly. Therefore, the further apart two channel numbers are, the less the degree of overlap and likelihood of interference.
If this won't work, Then consider buying a new wireless router as your current is deemed broken.
Good Luck.
Posted on Nov 10, 2010
Netgear N600 keeps disconnecting from internet
If your router isn't running firmware v 1.0.0.46 then download that from Netgear's website and upgrade the router's firmware.
Jan 28, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
My Netgear Router keeps kicking all wireless devices off the network
Upgrade your firmware for router (apps).
I hope, it helps.
Feel free to get instant Netgear router help at http://www.vtechsquad.com/wireless-router-support/ to fix any issues with your Netgear or any other router.
Jan 22, 2013 | NetGear Computers & Internet
Router repair
Disconnect the ISP modem power and network / cable. Do the same with the router. Wait a few minutes and reconnect starting with modem.
Oct 08, 2012 | Linksys Wireless-G WRT54G Router
I cant find my password to log into my wireless
You will have to go into the routers setup and chose a new password, If it requires you to enter the old password before it allows you to enter a new one , you can find the tiny reset button on the router and press it to restore it to factory default settings, be advised though, this will reset All the settings for your router, not just the wireless password, so you will have to configure it all again.
Jun 26, 2011 | Computers & Internet
Internet connection worked through my wireless router until recently on my Satellite L305-S5877. I have turned off my firewall to no avail. I have limited connection to the router wirelessly, but no...
First unplug all devices from your router. There should be a small button (mine is depressed with the point of a pen) on your router that is used to reset the router. I have to reset mine from time to time. Hold the button down for two minutes or so to allow it time to reset. If that does not work then disconnect your modem for a few minutes to allow it to reset Then reconnect everything in the exact reverse order that you disconnected. I needed to contact my router manufacturer the first time for help in resetting it.
Feb 15, 2011 | Toshiba Satellite L305-S5877 Notebook
WRT120N---I keep having to disconnect my linksys, unplug all 3 wires on the back of the router, wait 30 sec...reconnect the router...try to get online...when it works then reconnect the linksys....what am...
Please disconnect and internet link and try to access the the Linsys WRT100 management page and see the logs why the router is loosing the connection. If you dont get anything then it might be some issue on the device. A reset may solve your issue.
Please be aware the if u reset the wireless Router you will loose all your configuration and you have to reconfigure the wireless Router.
Please press the tiny black button at the back/beneath of the wireless Router and keep pressing for 2 minutes. The sys light will start blinking slowly and then rapidly. then release the button and wait for 2 minutes for the device to boot up with factory default settings.
Once you are done you can connect to 192.168.1.1 ip address and it will open the your Linksys Router management web page where you can reconfigure your wireless router again.
Hope this will fix the issue.
Best Regards
Jan 01, 2011 | Linksys RangePlus WRT100 Wireless Router
Cant find security key
You can connect directly to the router and reset the security key or you can reset the device to its factory default settings manually at the back of the router. You press the button and hold it in for a few seconds until it reboots itself.
Nov 02, 2009 | Linksys Wireless-G Broadband Router
Problems with my netgear wireless n- router model WNR834Bv2
Has your router been reset/rebooted recently? It sounds like it's been set to send wireless. Or it's possible you didn't secure it with encryption or a password on the route and someone got into it and changed the settings. Try rebooting it first (unplug power cable for about 5 minutes, plug back in) if that doesn't work, try loggin into the router with it's IP address and check the wireless settings. If that doesn't work, there should be a pinhole on it somewhere for the reset button, us a paper clip to press it for 5 to 10 seconds and this will reset the router to factory settings.
Sep 21, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Cant connect to wireless without rebooting my router
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
This many times fixes issues like your described.
Feb 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
Mar 08, 2008 | Linksys Wireless-G WRT54GX Router...
D-Link AirPlus DI-614+ Wireless Router Logo
63 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
