Question about Weller SP80 Soldering Iron
I need a replacement screw that holds the soldering tip in place,I removed the screw,to take out the solder tip which I cleaned and on replacing screw and tightening it as tight as I can get it the tip is not secure and slides out,have no idea what else the problem could be
    Brigadier General:
  • 4,088 Answers
Chances are that the screw and maybe the hole in the iron barrel have been 'cross threaded'. Remove the screw and the tip, then examine the screw and hole threads for thread damage. If they are, the screw should be replaced, but the hole in the barrel will need to be cleaned with the proper size tap. You can find the tap and the screw at a home center, or hardware store , plus get some suggestions on how to fix your problem. Hope this helps!
Posted on Jan 09, 2011
Do stained glass soldering tips go bad or stop working. I have a weller soldering iron that doesn't heat up hot enough to solder. is it the tip or the iron
If this is the dual trigger Weller gun and your tips are held in place by either set screws or by locking nuts, Just loosen both of the parts that are holding the tip to the gun and then retighten them back up. Soldering iron tips that appear to be tight might not be and this will insure that the tip is indeed tight and also cleans up the connection of the tip to the soldering iron. Oxidation from heating and cooling will cause a tip to not get very hot. Loosen the tip holder and then retighten it. Hope this gets you going again.
Dennis
Apr 15, 2017 | Weller Welding Tools
How to solder the ends back on a bake element
If the bake element terminal was shorted and burnt off, you will need to replace the bake element with a new element. Supply a model number and brand of appliance and I will supply a part number for you. Soldering will not hold as the solder will melt and break away shorting again. Possible to spot weld it if enough terminal left.
Mar 24, 2012 | Ovens
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
When i turn it on ..... i see smoke pls help
Do you like your radio medium or well done?
You may have hooked your power wire up backwards at some point and blown the polarity protection diodes.
This requires opening the radio and using a soldering iron to remove and replace the blown diode.
You will need:
1. Soldering Iron
2. Solder
3. De-soldering braid
4. N1004 diode or better.
5. Phillips head screw driver.
Using the phillips head screw driver to take the bottom cover of the radio off being careful of the speaker wires. Using the soldering iron, heat the solder on the tabs of the speaker and pull off the wires. No need to use the de-soldering braid to remove the solder. You should do this to make it easier to handle the radio, and to avoid damage to the speaker or wires etc.
Now take the cover off the top of the radio. This will reveal the "Trace" side of the board. This is where all of the components are soldered to the board.
Now flip it to the other side where you can see all of the components and wires etc. Look at the back right of the radio by where the power socket is. Look for D23. its a big black diode. It will most likely be black and burnt. Some times it may not be.
Here is the tricky part. You need to locate the points at which this component marked D23 is soldered to the trace side of the board. Some times you can use a bright light and look at the trace side of the board while the light shines on the other side to locate the part.
Once you have located the points at which the diode is soldered too, do not de-solder it yet. Make note of which side of the diode the white band is on. This is important, putting the diode in with the wrong polarity will make the radio not work.
After you take note of the white band you may now use the de-soldering braid to remove the solder from the trace side of the board. To do this, place the braid over the solder point. put the tip of the soldering iron on the braid and press it down to the solder point. You will see it **** the solder into the braid.
Once the solder is off both solder point, flip the radio and remove the bad diode.
Put the new diode in, making sure the white band is on the same side as the original diode.
Once again flip the radio over to trace side of the board and solder the new diode in. To do this place the tip on the solder point, making sure to touch both the solder point of the board and the wire from the diode. take the solder and touch it to the solder point, not the soldering iron tip. Once enough solder is on the point you can remove the soldering tip. Don't use too much solder.
Once both points have been re-soldered, solder the speaker wires back to the speaker. Red is positive, it connects to the tab marked by the positive symbol "+". The white wire is negative. It goes to the negative symbol, "-". You can just reheat the tab, and put the end of the wire into the melted solder and remove the solder tip while holding the wire in place until it cools enough harden again.
After the speaker is re-soldered, Put the covers back on. Now be very careful hooking up the radio to power. If you hook it up backwards again it will blow the diode again. Once the power wire is connected, turn on the radio, it should work fine at this point.
Good Luck!
Nov 16, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a Cobra 19 plus that doesn't turn on what do I need to check?
You have hooked your power wire up backwards at some point and blown the polarity protection diodes.
You will need:
1. Soldering Iron
2. Solder
Now flip it to the other side where you can see all of the components and wires etc. Look at the back right of the radio by where the power socket is. Look for D10. its a big black diode. It will most likely be black and burnt. Some times it may not be.
Here is the tricky part. You need to locate the points at which this component marked D10 is soldered to the trace side of the board. Some times you can use a bright light and look at the trace side of the board while the light shines on the other side to locate the part.
Good Luck!
Oct 20, 2010 | Cobra 19 Ultra II CB Radio
When i hook up my cobra 29 Ltd to my pickup it keeps blowing fuses, red to postive and black to negative..Cannot figure out whats wrong
You will need:
  1. Soldering Iron
  2. Solder
Good Luck!
Oct 07, 2010 | Cobra 29 LTD CB Radio
When i plug it to the power cord it blows the fuse
You will need:
1. Soldering Iron
2. Solder
Now flip it to the other side where you can see all of the components and wires etc. Look at the back right of the radio by where the power socket is. Look for D93. its a big black diode. It will most likely be black and burnt. Some times it may not be.
Here is the tricky part. You need to locate the points at which this component marked D33 is soldered to the trace side of the board. Some times you can use a bright light and look at the trace side of the board while the light shines on the other side to locate the part.
Good Luck!
Sep 14, 2010 | Galaxy Radios DX-66V Base CB Radio
How to replace power jack on sony vaio pcg-k33
Short version?
1.Remove the AC adapter if plugged in, remove the battery.
2.Wear an ESD wrist s-trap, and have it connected to a good ground. Work on a table, have a container with multiple compartments for the screws, and mark where each screw came from. There are as many as 65 screws, and 8 different sizes.
3.Completely disassemble the laptop, down to the bare motherboard in your hand. Remove the LCD screen assembly. No Processor, Cooling Tube, Heatsink, Ram Memory modules, CD/DVD drive, Harddrive, Wireless Antenna module, Keyboard, Nada!
4.Buy a replacement DC Power Jack.
Here is an example of one,
http://powerjack.us/index.php?main_page=advanced_search_result&search_in_description=1&keyword=Sony+Vaio+PCG-K33
5.Use the correct tools.
If you're a really experienced tech, you can use a 30 to 40 Watt soldering iron. No.2 tip. Have a clean damp sponge nearby, to constantly clean the tip.
Make sure the tip is clean and tinned correctly.
Or use a medium priced soldering station.
I advise using soldering wick, (Desoldering Braid), instead of a Desoldering Tool. Works much better.
5.Use the correct soldering procedures.
Linger too long when heating up the solder joint, to remove the DC Power Jack, and you stand the chance of burning the board. (Motherboard)
Also could lift the Circuit Trace right off of the board.
(Circuit Trace may be thought of as a very thin, copper wire on the motherboard. It isn't, but this explanation will do)
Do any of the two errors above, and you can use the motherboard for a Frisbee.
My method for removing the DC Power Jack, is to pull up on one lead at a time. Use constant pressure with my finger, and thumb. (Don't get 'Godzilla' on it. It can break. Everything has it's limits!)
I heat the solder joint for that one lead, and try to pull it up, a little out of the board. Then I move over to another lead, heat it, and pull up slightly on it. Keep moving from lead to lead, until finally they start pulling out.
After the jack is removed, the area needs to be cleaned. I use 90 percent Isopropyl Alcohol, and Q-tips.
CAUTION!!!!
This is HIGHLY FLAMMABLE! Keep it away from that hot soldering iron, and use in a Well ventilated area.
Always immediately return the cap to the bottle, and tighten the cap well.
Have fire precautions ready, just in case an accident happens.
Better Safe, Than Sorry!
The area of solder, around the hole in the board for the jack, may need to be buffed off. (Fine sandpaper in a tight roll, or a fingernail file using the fine side)
All areas that will accept solder need to be clean, and tinned.
Tinned, ...is the area is cleaned, a light spot of flux is touched around the rim of the hole, then solder is applied. The hole's rim then has fresh solder around it, and is ready to accept the DC Power Jack lead.
Be sure you have good solder joints! You may not see a cold solder joint, until you put the laptop back together, and the jack doesn't work. Then you get to take it all back apart, look at your solder joints, and go "OH".
This may help you in disassembling,
http://www.insidemylaptop.com/disassemble-sony-vaio-pcg-k-notebook/
Oct 19, 2009 | Sony VAIO PCG-K33P Notebook
R52WH74 with a convergence problem. I understand the solution is to replace the fl231 fuse and resolder somthing else. I have seen a video on youtube of how it is done. The fear I have is that I have never...
Resolder the Flyback Transformer pins. It looks like a Black Hand Grenade with a red wire out of the top.You don't need to remove any old solder / Just place the tip of the iron on the connection and let it melt the existing solder and add more solder to it while still holding the tip of the iron on the connection / then remove the iron and go to the next connection.Should be about 9 pins on that transformer.Be sure to unplug the TV from the wall outlet 1st !
Jul 29, 2009 | RCA R52WH73 Projection Television
When it's turned on, the light on my Princeton monitor blinks...
I just did this capacitor replacement today after reading these posts. It worked great! I used 470uF
35volt caps from radio shack. There are three 470uF caps two right next to each other and one off by itself on the printed circuit board. The values are easily seen on the side of the capacitors. Open the monitor by removing the screws and prying the halves apart using a large straight edge screwdriver. There is a metal cover over the printed circuit board that will come loose after removing screws around its edge. There are several wire sockets that must be unplugged to allow the circuit board to be flipped over to reveal the capacitors. The board itself is held down with three screws
Once you identify the capacitors, use a fine tipped soldering pencil to melt the solder holding the capacitors in place and remove them. Position the new caps with the dark stripe matching up to the lined marks on the board, carefully apply just enough solder to each terminal to hold the caps in place. Reassemble and you're done.
Sep 18, 2008 | Princeton Digital VL2018W Monitor
Weller SP80 Soldering Iron Logo
251 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Mike
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
