Question about Kenmore Washing Machines
Top of triple action agitator does not spin.can it be fixed or do i need to replace it?
    President:
  • 1,654 Answers
The problem is probably the little plastic tabs that engage the agitator, these tend to break after time. The motor coupling seems to wear out about the same time so you might want to get a repair man to change both of these. Should only cost around $100.00 dollers for both repairs, the parts are real chep for both of these repairs, it's the labor and service charge that gets you. Both of these repairs are not hard to do on your own if you are mech inclined.
Posted on Nov 10, 2010
  • Dcramer531
    Dcramer531 Nov 14, 2010
    .Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
    2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
    3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
    4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
    5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
    6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
    7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
    8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
    9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
    10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
    These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Washer agitator wont turn!
what do you mean wont turn, do you mean when it spins that agitator is stationary ? in that case you need a new transmission. if you mean that in a dual action agitator that you can spin the agitator top left and right with no resistance / the bottom doesnt move either, then you will need new agitator dogs. remove the top of the agitator and i mean the cap, some have fabric softner dispensers on the top, which means pull the green tab up and the dispenser will come off, then you remove the cap to the agitator. under that is the agitator cam. you either need a 11mm socket to take it off, or you will need a 1/2 in ratchet and extension to take it off. after that it should be very easy to replace the agitator dogs
Feb 07, 2011 | Washing Machines
AGITATOR WILL NOT SPIN, WATER WILL DRAIN BUT NO SPIN
Does your motor sound like it is running in the agitate or spin cycle or is it quite? If the motor makes no sound, then you need to replace the lid switch with this part.
If you hear the motor running in the agitate or spin cycle but you don't see any action, then replace the motor coupler with this part.
Dec 25, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
+whirlpool LSQ8243HQ0 water valve works. wont wash or spin. new motor coupling and timer.
Under the agitator you have what is called (agitating dogs). The agitator will have to be removed. The top should spin off, you will be able to look down into the agitator and see a bolt. Remove this bolt and the agitator can be pulled out. The agitators are small pieces of plastic with small teeth. These teeth get worn out over time or if the washer is overloaded. When the agitator free spins one way the teeth grab a (gear) on agitator and this is how you get the washing action (agitating). These dogs are easy to replace and cost about $5. If you need more info check out *how to replace agitating dogs)
Dec 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Kenmore 111 triple action washing machine. The top part of the agitator is not working but the bottom is. I am only able to do smaller loads. I have 4 active boys so this is not going to work. ...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Dec 08, 2010 | Washing Machines
I have a kenmore 22741 dual action washing machine and the agitator doesn't seem to be working properly. while it is agitating the top doesn't spin so well. I can put a little pressure on the top of the...
The "dogs" are the most likely problem and are a quick, easy and inexpensive fix.
Dec 05, 2010 | Kenmore 22422 Top Load Washer
The upper portion of the agitator (Kenmore Series 80 top load)stopped spinning as if the thread has stripped. What parts need to be replaced?
Basic top load, direct drive Whirlpool / Kenmore washers with two piece agitators use "agitator dogs" to allow the top section of the agitator to turn in one direction only.
These are plastic pieces and over time can wear.
See the following for how to replace them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
Bottom agitating, but top freely spins
You need to get an agitator repair kit. Remove the cap on the agitator. Some have a second inside plastic cover/cap. You will need a long extension and rachet and 1/2" socket to remove the hold down bolt. Remove and replace the parts with the kit parts. Replace the cover. 10 minute repair... online kit is about $13.00.
Aug 03, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator dogs stipped
the way to do this depends on if it is a dual action or triple action agitatior.
dual action
- Remove fabric softner dispenser
-pull off plastic cap with flat blade screwdriver
- bolt is under plastic cap 7/16"
triple action (bounces up and down)
remove fabric softenr and plastic cap
with a 1/2" drive socket extention, put into square hole and unscrew spring assembly. once unscrewed top portion of agitator will come off
May 27, 2009 | Washing Machines
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
