Question about Fisher and Paykel DD24DCTX6 Dishwasher
It gets stuck at 48 minutes - Fisher and Paykel DD24DCTX6 Dishwasher
I didn't get my minutes on my phone n i don't have any other phone to call technical support
You should probably wait for upto 48 hours for the amount of minutes to update. But if you have waited 48 hours, then just go to the service providers office. If you dont know the way, then just use google maps.
Sep 01, 2014 | Cell Phones
Stuck on a number, will not turn on or off
I would try shutting the breaker off for a minute then turning it back on. Most electronics that freeze up can be reset like this. Good Luck
Nov 10, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The drive pedal is stuck forward and wont budge along with the brake pedal...
Drop mower deck and have a look.
Both rods run to the rear on the right side.
Possibly something interfering.
Jun 17, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
HiMy name is Ray and i would like to increase the drying time on a maytag commercial dyer model lde19cs
i just got off the phone with Maytag Commercial Laundry customer service, because i needed to know how to adjust the run times on this dryer model. here is what i learned:
there are slots in the timing cam into which fit a white pin for adjusting the run time. the letter settings on the cam are set at 12 minutes apart:
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
if your dryer is running 48 minutes, that pin is likely in the 'B' slot. remove the pin. the built-in stop at the 'A' position is for 60 minutes.
May 28, 2009 | Maytag Dryers
Digital display stuck- machine wont work even after reset
Disconnect power from unit. Disconnect ground. Reconnect ground and make sure it is a good ground check hot and nutural to ground and should be line (110 to 120 V) on line (Black to bare) and 0-4 (with a electronic Volt Ohm Meter) White to bare. And again 110 to 120V from Black to White. Reconnect and if ground is stripped make new ground point with new screw. Modern electronics is required to have a good ground and without one readings like yours can freeze. If this dosnt work the board going to the display is most likely broken.
When replacing the board always ground your self before removing the board from the box and plastic bag. This will drain off and static buildup and prevent discharge across the board. (not as much a problem in humid or warm weather).
Apr 23, 2009 | Dishwashers
Lifestyle 48 Stuck Error 002
My husband left the power unplugged overnight, and by the next morning everything worked fine. Mystery!
Sep 08, 2008 | Bose Lifestyle 48 System
DMC 4 installation problem
idk i think u should try cleaning the disc
Feb 25, 2008 | Sony Playstation 3 (PS3) Console
Display Stuck
press the "Previous" or "Last" key that is right of the number "0"
Aug 26, 2007 | Bose Lifestyle 48 System
Fisher and Paykel DD24DCTX6 Dishwasher Logo
46 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
