Question about Compaq Presario Notebook
Memory upgrade for presario 2100 notebook
Where are the memory modules located on the presario 2100, by access from bottom or thru the top side under the keyboard? I do not have a manual and I am upgrading this for my folks. If it is under the keyboard, what are the steps to remopve this module to gain access?
Thanks!
Cal, Email: w7izl@nctc.net
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
Hope this helps . Just follow this steps.
1. Turn off your laptop and turn it on the reverse side. (under the keyboard see picture)memory upgrade for presario 2100 notebook - c4c84c4.jpg
2. Remove screws and cover .
3. Remove the locks on both ends of your memory (encircled in yellow) . This is done by holding the locks on both sides using youmemory upgrade for presario 2100 notebook - 9ae5cd5.jpgbr />
4. While holding the locks gently push the locks away form the memory (sideways)
5. The memory will popout and you may now remove and replace it with a higher capacity.
Note: This is only done if there are no available slots for the new memory. If a slot is still available no need to remove old memory. Just insert the memory on the available slot
Posted on Jun 17, 2008
  • 63 Answers
Access is through the bottom. A service manual for the 2100 is located here, but you shouldn't even need it. One or two screws and you're in.
http://h10032.www1.hp.com/ctg/Manual/c00246219.pdf
I want to upgrade my Laptop NX 5000 RAM which is currently 256 mb. Please suggest in details what type of ram is reqd i.e. DDR, DDR1/2 and what about 180/200 pins
You can upgrade to 2GB.
(1024MB.
512 MegaByte + 512MB = 1024MegaByte
1024MB = 1GigaByte )
It is DDR Sdram.
(Double Data Rate Synchronous Dynamic Random Access Memory)
It is also SO-DIMM, as used for laptops.
(Single Outline Dual Inline Memory Module)
http://en.wikipedia.org/wiki/SO-DIMM
There are 200 gold plated contact pins. 100 on each side,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Note the Locating Notch on the bottom, and how it is off to one side.
Note the Side Notch on each side.
There is a Locating Lug in the bottom of the ram memory slot, for the laptop.
The ram memory module must be turned to the Locating Notch lines up with the Locating Lug.
There are spring clips on each side of a ram memory module.
The tops of the spring clips are eased to the outside.
This allows a bump, or protrusion on the spring clip, to come out of the Side Notch.
When the ram memory module is ensured to be seated correctly, in the ram memory slot, the spring clip 'bump' will be in the Side Notch.
A laptop ram memory module is removed AT AN ANGLE!
NOT too much more than the angle it is in, when installed in the ram memory slot.
After the two spring clips are eased out, the ram memory module will pop up a little bit.
Slide it out AT THAT ANGLE.
If you it up to a straight up position, you will damage the gold plated contact pins of the ram memory module, and the contact pins in the ram memory slot.
Damage the contact pins in the ram memory slot, and you are looking at motherboard replacement.
Everywhere on the ram memory module is the BODY, except for the gold plated contact pins.
Handle the ram memory module by the Body.
The Body is coated with a see-through protective plastic.
Refrain from touching the gold plated contact pins.
[ DDR Sdram IS DDR1. Double Data Rate Sdram.
DDR2 Sdram is Double Data Rate 2 Sdram.
DDR3 Sdram is Double Data Rate 3 Sdram,
1) http://en.wikipedia.org/wiki/DDR_SDRAM
2) http://en.wikipedia.org/wiki/DDR2_SDRAM
3) http://en.wikipedia.org/wiki/DDR3_SDRAM
It is the Technology used, not referring to the size ]
DIMM for desktops, Dual Inline Memory Module
SO-DIMM for laptops.
Single Outline Dual Inline Memory Module.
You need SO-DIMM, with 200 pins, and it's Frequency Rate, ('Speed'), is rated at 333Megahertz. (333MHz)
That is PC2700.
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=449877&lang=en&cc=us
Under the bold black subheading -
Resources for HP Compaq nx6110 Notebook PC,
click on - Manuals
Quick jump to manuals by category:
,click on - Service and maintenance information - in blue.
Under the subheading - Service and maintenance information -
,click on -
HP Compaq nx6110, nc6110, nx6120, and nc6120 Notebook PCs -
Maintenance and Service Guide
(1 Oct 2005 )
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name above, it may take up to 30 seconds, before the first page comes up.
In the Bookmarks menu to the left, click on the + sign to the left of -
Removal and Replacement Procedures.
Scroll it down, click on -
6.7 External Memory Module
There is also an Internal Memory Module -
6.17 Internal Memory Module.
You can put UP TO 1GB in the Internal memory module slot, and UP TO 1GB in the External memory module slot.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 10, 2012 | HP Compaq nx5000 Notebook
Where dom i insert new memmory in a dell latitude d820 computer?
1. Remove the keyboard bezel with a flathead screwdriver.
2. Remove three screws securing the keyboard
3. Unplug the keyboard cable from the motherboard and remove the keyboard. The internal RAM (memory) slot is located under the keyboard, right above the touch pad buttons.
-How to remove keyboard ( with pictures ) -
http://blogs.microsoft.co.il/blogs/tamir/archive/2007/11/16/diy-how-to-replace-your-dell-latitude-d820-keyboard-for-only-13-99.aspx
Aug 21, 2011 | Computers & Internet
Product data sheet claims there are 2 memory bays but I find only one back in the memory expansion bay. How do I access the second (hidden) memory slot?
Some model laptops have memory slots in different locations.
One would be on the bottom of the laptop and one would be on top of the motherboard under the keyboard.
The memory slot on top of the motherboard would already be fitted with a memory module and only needs to be replaced with a larger RAM module if required.
Mar 29, 2010 | Toshiba Satellite M35X-S149 Notebook
Satalite m35x-s161 how to replace the keyboard?
Toshiba Satellite How to remove keyboard and upgrade memory modules. This post was written by cj2600 on April 28, 2006
Posted Under: Toshiba Satellite A20/A25 --> toshiba-satellite-a20-a25-memory.jpgRemoving and replacing memory on a Toshiba Satellite A20 or A25 notebook is not as easy ad it should be. Both memory modules are located under the keyboard. A laptop keyboard has to be replaced in order to get access to the memory modules. Before you remove the keyboard do not forget to remove the laptop battery or you can damage the laptop. Be careful when you remove the keyboard securing strip; do not bend it too much. To remove the memory module from the slot on the system board, release the latches on both sides and the memory module will pop up. It will stay at a 30 degree angle to the system board. Firmly grasp the memory module and remove it from the slot.
Oct 31, 2009 | Toshiba Satellite M35X-S161 Notebook
Want to know how to upgrade my lap top memory thank you
To upgrade you will need a SoDimm 2gb DDR II SDRAM, 667 MHz module, on the bottom of the notebook you will need to remove the panel usually secured by 4 screws to gain access to the memory slots, you probably have a 1 and 2 gb modules already so it'll mean removing the 1gb chip and discarding it as you only have 2 memory slots so you can fit the new 2gb module.
Jun 10, 2009 | Acer Aspire 7520-5185 Laptop
Cant find where the ram is to replace with upgraded ram
This is not as easy as the trap door on the bottom but it's not to bad if you just take your time. Remove power supply and battery. Follow all safety rules.
The memory is located under the keyboard. Take your time, open the screen to full open position, locate the small slot to pry the strip around the buttons at the top between the keyboard and the screen. Slowly work around until it all pops off. Then you will see three small screws at the top of the keyboard, remove them and look for a small pry point along the side of the keyboard. Don't just pull it off as it is still connected via ribbon cable to the mainboard. You will see a fabric tab at the top of the connection, pull on that until it releases. And there you'll see the spot...You can only increase your memory to one gigabite...no more than 512 MBs in each of the slots. PC-2100 (266MHz). It does not support dual memory nor do you need to install in pairs. Put things back the way they came out and you are finished. Once you have done it, it is not bad at all...take your time and force nothing.
Hope this helps, please leave rating, thankyou kindly
Apr 26, 2009 | Computers & Internet
Location of memory slots
Hi.There are a set of instructions that we need to follow for the upgrade process.You can increase the amount of RAM (random access memory) in the notebook with an optional memory module approved by Compaq.The notebook contains 2 memory slots, one of which is accessible for an optional memory module upgrade.Please refer to think link and select the Hardware Upgrade option in the list in the file which will guide you thru picturised views for helping in the memory upgrade.Link is : http://h10032.www1.hp.com/ctg/Manual/c00090108.pdf.
Please let us know whether this help or whether you need more help
Mar 16, 2009 | Compaq Presario R3000 Notebook
Upgrading RAM Memory
hi dear ...almost 80 % position of memory module (RAM) it 's same
there are in back panel of your notebook
open the sheet, you can see there are slot for your RAM, just put in ther with right direction
oke
have a nice try
cropp
Mar 23, 2008 | Compaq Presario Notebook
Memory Slots
I wasn't able to find where exactly your memory modules are located, but there are either on the bottom of the laptop with just a screw and plastic cover on top of them, or they are underneath the keyboard.
Here are the specs for the Armada M700. This will let you know what type and how large you can take it too.
Nov 15, 2007 | Compaq Armada M700 Notebook
Compaq armada e500 memory
memory modules are under keyboard,you have to remove this first,1 hidden screw under(indicates a keyboard) and the 4 holds between the Fkeys(pull them down).Remove the keyboard and you''be able to see them....Chris/Greece
Nov 13, 2007 | Compaq Armada E500 Notebook
Compaq Presario Notebook Logo
102 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
