After a trip out of state, my garmin will not let me enter my state. it goes right to match not found after one letter
J2zen-
Thanks for your post. Went thru your suggested steps but still had no success. Will keep trying!
I just posted the same problem then played with the unit and determined that you need to go back to the main page which lists Where to?, VFiew map, and Travel kit. In the upper right is a wrench. Click on the wrench then select locale and then select change all and go through the entire process. Once you select the correct time zone the unit works.
Have you tried the reset button?(It has a label over it) it may be be locked up software, and requires a "reboot".
I took our Garmin to Hawaii and it worked fine. Once we returned to the mainland it will not allow me to enter a state. After entering one letter it says no match found. Tried the reset button with no success. Any other ideas?
Cannot enter states. Reset did not work.
