Question about Toshiba Satellite A135-S4527 Notebook
Good Day Sir, I use a toshiba Sattelite A200-1NV laptop which if i connect the ac adapter, it charges for about 30 seconds then stops charging and the battery icon goes off. I use a windows vista. Your help will greatly appreciated. Thanks
  • 2,567 Answers
Please refer to the following article for a detailed diagnosis procedure:
Troubleshooting Laptop Power Failures - The Battery
Posted on Nov 10, 2010
Toshiba satellite c55t wont power on, just blinks once every 4 seconds
check power cord is fully inserted into laptop
if no joy
try also forcing a power down by holding in the power button for 30 seconds and then try power button again to power it up .
might be in hibernate mode !
Dec 04, 2017 | Toshiba Computers & Internet
My LGMS323 Won't Charge Or stay on
Try another AC adapter. Next with a known good AC adapter try wigging the DC connector at the notebook. Watch the Charge light carefully.
Finally try removing the battery and then press and hold the power button for 30 seconds. Then re-install the battery and connect the AC adapter and power on.
Jan 05, 2015 | Computers & Internet
Laptop battery charges for 30 seconds and then stops
Dear Lauren Monge
The problem is in one of two,1st charge plug in your lap or the adapter itself and its plugins
Best Regards
Mazagange
Mar 28, 2013 | Dell Vostro 1710 Laptop
My toshiba satellite series a135-s4656 laptop stopped charging for over two weeks now. Though the adapter (power pack) is functional. Please what do i do (cos the system has been down since)?
How do you know the ac adapter is working? Just because the light on the ac adapter is on doesn't mean it's working. Does it work with the ac adapter plugged in? Just not charging the battery. If in the first case just buy a new ac adapter and see if it works, most are affordable some not so much. If the battery isn't charging then you will have to shop for a new battery. If both of those are good then you have either a bad ac plug on your laptop, or motherboard issues. Hope this helps, if you have more questions just reply and I will try to help.
Aug 01, 2011 | Toshiba Computers & Internet
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
We noticed today that the battery does not charge, nor will the laptop operate with only the power adapter connected. I've verified that the power brick is putting out the correct voltage. If I...
Check if the AC Adapter brick is getting warm when connected, if not then you need to replace the Adapter.
If AC Adapter brick is getting warm and still its not charging the Battery, please perform the following steps.
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Note: With an extensive use of the notebook, some times notebook would store some static charges which indeed will stop the notebook from powering up or charging the battery.
The procedure to remove this static charges from the notebook is known as power drain.
Performing a power drain procedure will not effect any personal data or delete any pictures from the hard drive on your notebook.
If issue persists, contact Notebook manufacturer for further support.
Oct 15, 2010 | Computers & Internet
Today my cord for my toshiba was behind my pillow and i was lying on it. and I didnt notice, but then it showed that my laptop wasnt charging did my cord just get too hot? will it work later?
The power adapter does not have a temperature sensitive device, therefore it won't stop for overheating if not in consequence of a fault.
Try leaving the power adapter unplugged for about ten minutes.
In the meanwhile also remove laptop battery and put it back.
Connect it back to AC and laptop.
Ensure that connection to laptop and power cord connection to AC adapter box are both well plugged.
Before turning on laptop leave it connected for few minutes.
If laptop still does not turn on and battery does not charge, then the AC adapter is faulty.
A further test can be done using a multimeter to read voltage on AC adapter plug.
A replacement AC adapter is not expensive and can be purchased online. Try entering in Google your Toshiba model followed by the words "power adapter".
Aug 15, 2009 | Dell Inspiron 5100 Notebook
"Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Feb 18, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
Toshiba Satellite A135-S4527 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
