Question about PDE Technology ZipSpin DVD CD Master Burner
Machine will not read master dvd. Disc is clean : face down : been finalized: not scratched: dvd+R to dvd+R & master will play on dvd player I am using memorex dvd+R machine won't tell me the bytes or anything. After this I push the button to open tray bottom tray will not open until I turn machine off and back on. I just gotten this machine so any help you can give me would be great I needed to use this machine like yesterday
The player will read dvd but will not play cd
Richard: This is what EHow.com said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more : http://www.ehow.com/how_2036285_use-dvd-cd.html
    May 28, 2015 | Televison & Video
    DVD will not play on any dvd player in the house after playing it in the SONY BDP S270 Blu-ray player purchased from Walmart. After playing the DVD in the Sony blu-ray, I can't play it in any or my...
    did you mean your DVD disc can not play in some dvd players,if so then my answer to your querry would be that some dvd players have more powerful lens to read bulky data in a disc that some machines can not read. also note that some machines are very sensitive such that they do not play discs with viruses,with scratches or any other defects. this is to safeguard the lens from being damaged due to the same though some machines will play barely all discs no matter the scratches.
    Sep 25, 2011 | Sony BDP-S270 Blu-Ray Player
    When we put a disc in to play it, the player just continues loading and never actually plays the disc. what could be the problem? It is plugged into a wall outlet when we are trying & we have tried...
    Check DVD discs for cracks,big scratches,dirts and grims?All DVD dics are original discs like comercial movies or materials discs?Most DVD players have problems,reading and playing copy discs,because of it finaling codes of the DVD copy recoders players used it to coping it.
    Feb 25, 2011 | Sylvania SDVD8732 Player
    Disc error shows when playing dvd
    You may need to get the discs repaired or it may be your laser in the player need cleaning. Easiest soloution is to basically clean your disc(playside). Check for scratches on both sides of your disc. If the label side is scratched in any way, it might be unrepairable as this is where the data is stored, if the playside is scratched they are repairable. You can try home remedies if the scratches are very slight, if not professional repair is required. Try other discs in your player, if they are not working either, then it may the players laser is dirty and may need a laser cleaner, fairly cheap in some stores.
    If it's the disc thats scratched visit www.discREPAIR.ie for FAQs and futher help or disc repairs.
    Mar 07, 2010 | Zenith DVB412 DVD Player
    My disc records fine, plays great on the Magnavox, but no other player can read the disc?
    You must finalize a disc before it can play on other machines. Please refer to your documentation for how to finalize a disc.
    Jan 11, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
    After inserting a disc the dvd goes into the machine, the menue box on the tv screen changes to loading, stays on loading for a short time then pushes the dvd back out. The machine never changes to play.
    the dvd player is unable to read the disc. either the disc is scratched and cannot be read or the player needs cleaning. cleaning discs are available pretty much anywhere. sometimes simply blowing into the area when the tray is open can temporarily fix the problem.
    Nov 17, 2009 | Mintek DTV-263 26 in. LCD Television
    I burned & finalized a DVD+RW with family
    while u were burnin the disc which format of disc u selected.......if u selected data disc then some of the dvd players will not read those dvds..............u should not select data disc .................instead there r some options to burn the disc....it depends on which version of nero or the cd burner product u use
    Oct 14, 2009 | Sylvania Televison & Video
    Dvd recorder can't read disc it previously read
    Take the Disc out and put it aside. You must clean the Laser Eye, and clean dust and other matter from inside your recorder. Clean Eye with rubbibg alcohol and q-tip. A regular CD/DVD cleaner disc will not work. After cleaning, reinsert your Disc and Finalize it.
    Jan 02, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
    Ps2 keeps saying disk read error everytime disk is put in no matter what disk is put in what can i do to fix
    • Confirm the disc is inserted correctly into the PlayStation 2 console (label side should be facing up when the PlayStation 2 console is in the horizontal position).
    • Confirm the disc is clean. To clean a disc, use lint-free cleaning cloths made specifically for cleaning CD/DVD discs, sold at computer software stores. When cleaning the disc, we recommend starting from the innermost circle, and wiping out to the edge in a straight line. We do not recommend wiping in a circular motion, as it may create more scratches on the disc. [Note: Other materials, such as a paper towel or a T-shirt, may also scratch the disc. If there are any scratches, smudges, or fingerprints on the disc, it may not function properly.]
    • Try playing different CDs, DVDs, and games on the PlayStation 2 console to see if the problem exists across multiple discs.
    • To determine if the problem is with the disc itself, try playing the disc on a different PlayStation 2 console (or a PS oneTM or a standalone CD/DVD player, if applicable).
    • Confirm that you are not using any game modification devices. Unlicensed devices such as game modification devices can interfere with the proper function of the software. We do not recommend the use of any game modification devices or unlicensed products[1].
    Dec 17, 2007 | Sony PlayStation 2 (PS2) Console
    PDE Technology ZipSpin DVD CD Master Burner Logo
    82 people viewed this question
    Top PDE Technology Computers & Internet Experts
    Alun Cox
    David Payne
    David Payne
    Are you a PDE Technology Computer and Internet Expert? Answer questions, earn points and help others
