Question about Atari 2600 Console
Atari 2600 Jr. Video Issue
I recently dug my old Atari 2600 Jr. out of the basement in order to relive my younger days and ran into an issue with the video display. When I put a game in such as E.T. The opening screen display T.E. On other games I will see three different images of a tank or whatever. Also when I try to move in some games I can see the image but it is jumping around from spot to spot. I currently have it hooked up to an older (10 year) old RCA television. I have it hooked into the coax and have the antenna menu set to air not cable. I hooked it through the coax using a phono to F type coax, through a 300 ohm to 75 ohm transformer and even tried to modify the atari for a composite video output to no avail. I have tried 20 games and none work properly. I have now removed the composite modification that I made in order to use the two more common installations. I'm pretty sure that it is the console but am not sure which chip etc. needs to be looked at. Any suggestions or has anyone seen this before. Thanks
  • 2,794 Answers
You can't run a 2600 on composite. Even though the connector looks the same it isn't. You need a RF modulator to seperate the signals and you need an old school one that has a manual switch on it. Check at Radio Shack they carry things like that.
Modulators with AV jacks like I use for watching my DVD on when I only have a coax on my television won't work becuase the atari line doesn't separate the signal outside the box by audio and video. That wasn't something being done 30 years ago. In fact it wasn't being done until NES came out.
If Radio Shack doesn't carry it you can probably find one on E-Bay.
You can always find classic Atari 2600 games for your PC. I know I play the Activision Games that way from time to time.
Good luck on that.
Posted on Jun 17, 2008
What was the last game officially released by atari for the 2600?
Xenophobe in 1990 was the last game atari released for the 2600. However, 3rd parties have released games for the atari 2600 as recently as 2008 (Actionauts)
Jan 29, 2013 | Video Game Consoles & Games
I purchased an atari 2600 junior on ebay recently. It turns on fine, the cartridges have been cleaned (by myself). I have a female rca to male coax adapter to attack the rca cable to. I then attach that to...
Try switching to a different channel. The Atari 2600 supports channels 2 and 3, you want to pick the one that is not broadcasting in your area. If your TV has "auto-tuning" you may need to manually add channel 2 or 3 (whichever you pick) to see it on the TV.
Jun 17, 2011 | Atari 2600 Console
How on the atari 2600 does does the console connect with the tv?
Hi Atari 2600 console us a old style cable called an RF cable and connects to the TV arial inlet. see www.gameoz.com.au as they stock this cable and gear
Sep 22, 2010 | Atari 2600 Console
I just got an Atari 2600 and the hard wired video cable's male connector is broken. is there a way to fix this? The cable is hard wired to the Atari.
I think that you need a new video cable then that should fix the problem if not then
it would be an internal issue with the console.
Aug 18, 2010 | Atari 2600 Console
Atari 2600 Jr doesn't turn on
Sounds like the power supply\power converter has finally given up the ghost. It will likely cost you more than it's worth to fix it. You'll have to fix it yourself most likely. I would look for burned-out or popped capacitors to start off with. They are likely culprits in even computer systems when the power goes out. With something as old as an Atari 2600 it could be just about anything.
Jun 15, 2010 | Atari 2600 Console
Trying to find a plud/ adaptor for atari 2600
Lukie games sell atari 2600 ac adapters and atari 2600 joy sticks too.logo.png
Feb 28, 2010 | Atari 2600 Console
Just hooked an atari 2600 jr. up to a lcd television, everything works fine except for the select and reset buttons.
Had the same problem with an atari 2600 jr I just purchased. The reset and select buttons are imprinted on a plastic film and it has probably deteriorated.. I repaired the traces in mine with aluminum tape, but It would not be dificult for someone with a soldering iron to replace them with real buttons purchased from radio shack. (It's only 3 wires)
May 02, 2009 | Atari 2600 Console
Atari 2600 jr. console + paddle controls = Don´t work !!!
get a refund for the item
then buy a new console
Sorry but thats the only way your gunna get this to work :(
pls rate.
Dec 17, 2008 | Atari 2600 Console
Possible Control Port Issue for 2600
Superdrafan:
you sound like you have a conection problem within you atari
open the Atari up and look to see if there are any dry solder joints from the joystick ports
just dabbing the point with a solder iron shold freshen up the connection
The Gameboy: you sound like you have dirt in your joystick
open it up and clean the connections with a cloth and spirts
Sep 04, 2008 | Atari 2600 Console
Atari 2600 Jr. left on overnight, next day no color
Flip reset switch, then retry b/w/color selector (or switch from ch. 3 to 4).
Apr 08, 2008 | Atari 2600 Console
Atari 2600 Console Logo
308 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
michael galang
EnergeeUK
Level 1 Expert
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
