Question about Whirlpool WFW9450 Washer
My whirlpool washer is outside in a patio i plan on enclosing.meantime i need to prevent from freezing. in past with an older washer i added antifeeze and started the agitaion cycle long enough to circulate the additave. i'm not sure how to do this with this newer washer. please help or offer any other suggestions.
    President:
  • 1,654 Answers
What I would do is either remove all the water lines and blow them out with compressed air and drain it completly if you are goinfg to store it for a while. If you stll need it and have to use it you might want to try the Red colred Rv and marine antifreeze. I think you can add half of the gallon and put it on a cycle that starts the discharge pump, allow it run just long enough to pump the antifreeze into the dischage line and make sure it is coming out of the hose before shuting it off. This should allow enough of the antifreeze to get in the lines and keep it from freezing. You still have to worry about the water lines connected to the machine. heat tape might help there!
Posted on Nov 10, 2010
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
My washer keeps stopping in the middle of a cycle and i keep having to hit the start button. what is the problem?
How old is the washer? Older washers used contacts inside the control module (typically an enclosed unit) and over time, carbon builds up on the contacts and eventually, good contact cannot be made anymore.
Feb 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool fills with water after the machine is turned off. How can I fix it?
sounds as if you have a bad inlet water vavle, it doenst complety shut off after use, and waer will trickle in( adding up to quite a bit in a day) youll need to replace the water inlet valve(directly behind themachine where the hoses hook into). in the meantime turn off water inbetween uses
Mar 17, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water filling to washing level when washer is not being used.
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When the washer is off, even if the door is left open, the tub will fill with water and leak onto the floor.
Whirlpool duet wahser not draining
Hello there. in the meantime, you can try cleaning out the pump. This is how: There is a kick plate underneith the door and below that plate there are 3 (hex) screws.
Once you take the plate off, there should be a filter right before your eyes.
Whirlpool makes it easy to access it. Clean the filter and I think you'll be ok.
Try that first before you spend $79 on a service technician. Here is a picture of how it should look: http://www.flickr.com/photos/21558886@N00/2710225237 Thanks for your inquiry and using fixya. Hope this helped :)
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite side by side refrigerator freezer
if you will be affected by freezing weather, it is advisable to drain all water from your reservoir to prevent from freezing and can damage the plastic tank.
if not, then it is safe just to unplug it and leave it. clean.
tnx 4 using fixya,
drcool
Oct 21, 2008 | Refrigerators
Washer will not drain or spin motor making clicking noise
Likely has debris in the filter.
Open the bottom access panel (3 screw on bottom front lip)
open the filter access and be ready for some water spill ,have towels.
clean and check the pump impellers for freedom of movement.
if you still have noise after this you may have to go deeper past the pump and remove the hoses as the debris can be past the pump now.
Or take the machine outside and run water up the pump using a water hose to clear it. be inventive
Oct 26, 2007 | Whirlpool GHW9100L Front Load Washer
Whirlpool WFW9450 Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
