Question about GE DLSR483EE Electric Dryer
GE DRSR483EGWW dryer knobs keep breaking. When I place the knob on the timer, it breaks after a few months. I have used every knob and they all have cracked. Does anyone have a suggestion?
SOURCE: GE Profile Prodigy Electric Dryer start knob turns too far
The knob is broken and needs to be replaced.
Posted on Sep 01, 2008
  • 126 Answers
SOURCE: Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Posted on Dec 13, 2007
  • 161 Answers
SOURCE: Dryer replacement timer knob for GE NBR453EAOWW
Go to the junk yard or a used appliance dealer.
Posted on Jun 29, 2008
MNTECH
  • 1543 Answers
SOURCE: timer switch on GE washer
You don't state your exact model number, and the number off the timer is not the actual part number (it's some sort of part stamping number). Most likely what has happened is a plastic tab on the timer housing (which normally goes into a slot in the metal, and thus holds the timer at that point) has broken off. The fix is to replace the timer, but instead of buying a new timer, I usually fashion a Z type piece of metal which I can put one screw though into the metal and the other side holding the timer against the metal. Takes a little work, but it's a lot cheaper than a new timer.
If you want to take the timer knob off, you have to pull it out and use a thin tool, like a small screwdriver, to push the plastic clip off the shaft behind the knob, allowing the knob to then come off the shaft. Push the clip back on the knob when off, so that all you have to do to reinstall the knob is push it on and it will lock on the shaft again.
Posted on Dec 08, 2008
docjohn174
  • 943 Answers
SOURCE: my ge dryer wont start
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Posted on Dec 16, 2008
What can cause an electric GE dryer to not start? Model number DCVH680EJ1WW. cogtinuity with motor switch, door switch, high limit fuse, thermistor & no cogn. with the thermodisc or heating element.
As a repair technician, just came across this crazy situation with GE / Hot Point / Moffat machines several times. It is all made by GE corporation.
The Dryer is not starting because your cycle selector knob is broken inside and it is just turning without turning the timer selector.
GE corporation machines are good. But those damn chinese plastic knobs break from inside. I have driven 50 km to find out the knob is broken. I had to charge the poor customer.
Apr 15, 2015 | GE Dryers
Need knobs for ge gas range WB03T10295. All broke within six months after getting stove. All I can find are in the $30 range each which is obsurd. Any suggestions?
hey kim wassup? i m curious about how you managed to break all knobs so soon!! pl z handle it carefully, and try entering in the kitchen leaving all your frustration in bedroom.
so that in future you don't have to spend on same. ok? cheers!!
Nov 03, 2013 | GE KNOB GAS VALVE CH - WB03T10295
My dryer knob has broken again. Wich direction should I be turning the knob when choosing a drying cycle? I was told I was turning wrong direction.
GE dryers turn in the clockwise direction and if you turn in the counterclockwise direction you could break the stops off the switch.
Jun 20, 2011 | GE Dryers
Starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Jan 04, 2010 | General Electric WHDRR418GWW Dryer
Buzzing noise when i turn the timer switch
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 06, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
How to remove front panel of dryer
Be sure to unplug the machine from the mains,
1.-Remove the top cover of the machine, very straight forward.
2.-Unclip the universal coupling from the main timer to the back of the knob.
3.- The whole knob assembly is held in place by a backing plate.
4.- There are 2 clips at the top of this backing plate raise them and the backing plate and knob can be pulled out.
5.- there is a plastic clips but be careful not to break it.
Your ffeed back and ratting are so important for me. thank you
Was this helpful?
The knob breaks when it has been turned in the wrong direction several times. It's a safety device so as not to damage the main timer.
May 20, 2009 | Dryers
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
Oct 15, 2008 | Whirlpool GGQ8831L Gas Dryer
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE DLSR483EE Electric Dryer Logo
421 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
