Question about Whirlpool Calypso GVW9959K Top Load Washer
My whirlpool sm8525147 just stopped working after it filled up with water. I tried seeing if it tripped the breaker.
    President:
  • 1,654 Answers
Most likely the timer has quit but without more info I can't say for sure. This is typically what happens when the timer quits or burns up.
Posted on Nov 10, 2010
Whirlpool washer SM8525147 just stopped working
well do you have power if so may be timer or if it wont spin could be lid switch. so make sure it has power
May 20, 2012 | Whirlpool Washing Machines
Hello, after the first fill it will trip the circut, I have tried what I believe to be a different circut with the same result. Washer still full of water, please help.. Thank you for any help. Model# ...
Check to see if this may be caused by a Ground Fault Interrupter. If water has gotten into the electrical system of the machine, this will continue to trip until the fault location has dried out and no longer causing electrical leakage. If this is a standard breaker that is tripping, this would mean you have a shorted motor causing it to draw excessive current.
The combination breaker/GFI can itself fail; I replaced several of these after only a few years of service.
Aug 08, 2011 | Whirlpool Washing Machines
I have a Whirlpool AD75UST humidifier that stopped running, almost like it blew a fuse or something. Does it have a fuse somewhere? Any other possibilities? Thank you!
Have you checked the receptacle it's plugged into, to see if it's still working? Use an electric lamp to check this. If the lamp doesn't work, the circuit breaker in the home's main panel has been tripped. Unplug the dehumidifier and reset the circuit breaker. Then plug the dehumidifier back in. If it trips the circuit breaker again, there's an electrical problem within the dehumidifier.
In answer to your direct question ... some dehumidifiers have a reset switch. It's probably on the back of the unit, above the water collection tub. if all else fails consult your Owners Manual's Trouble Shooting Guide. If you have misplaced it, you can download it from the Whirlpool Appliance starting at their home page.
Hope this helped head you in the right direction to solving your problem.
Mar 01, 2011 | Whirlpool 75-Pint Dehumidifier
New whirlpool wtw5100VQ, will not fill hot/warm water,
Remove lid and just check connectors on rear of inlet vaulves are not earthing. Hope this helps. Also to check it is not a faulty solonoid remove wires from 1 terminal and tape them up, then put machine onto hot fill, if this does not blow trip switch then solinoid most likely at fault. Please ensure you disconnect power before touching wires. Good luck hope this helps
Feb 12, 2010 | Washing Machines
Whirpool Range suddenly tripping the circuit breaker
It could be one of the elements is shorting out causing the breaker to trip. Try using one burner at a time to see which one causes the short.
Aug 21, 2009 | Whirlpool RF262LXS Kitchen Range
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
NO Agitator, draining or spin
Since the breaker did not trip i am going to assume that the washer stopped because the motor overload switch tripped or contacts burnt. Was there any smell of any burning (electrical burning)?. It could have stopped because a contact on the timer got burnt too. Have a look also at the water level swirch
Regards
Oct 04, 2008 | Whirlpool LSB6200KQ Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
207 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
