Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
