Question about GE WBSR3140DW Top Load Washer
Oil leaked into the washing machine tub.
A green oil came from somewhere in the washer and ruined the load of clothing in the washer. Does this mean the trasmission has a blown seal/gasket and needs replaced? Or is it a water pump problem within the washer?
  • 1 more comment
  • Mark Sealover Jun 21, 2008
    The green stains were actually dark brown. As it turns out the the seal to the transmission was bad. The water works it way down into the trans through the bad seal and pushes the oil out back up into the tub. I pulled the agitator and wiped out the entire tub, replaced the agitator and ran another wash load (without clothes), pulled the agitator and found more oil at the bottom of the tub.
  • wolfe_cub Mar 14, 2009
    I have the same problem is there a way i can fix it myself or is it a major thing.
  • Anonymous Mar 14, 2009
    I have the same problem.It just happened
  • 1,028 Answers
There is no green oil in washer softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
Posted on Jun 17, 2008
After some loads, what appears to be gear oil (about 8 or 10 streaks of it) shows up on the inside of the agitator. I thought it was just years of buildup, so i cleaned it and ran through a small load. ...
GE washers are notorious for transmission leaks. Personally, I wouldn't spend much time or effort on a major repair of a 14 year old washer. Suggest you contact a local parts house and see if the upper seal is available as a kit. Other sites suggest that this transmission is no longer available new, and even then it's a $250 part. If you ruin one load of clothes with transmission oil, you're probably halfway to the price of a new one.
Apr 19, 2017 | GE WWRE6260D Top Load Washer
Greasy marks on clothes in top loading washing machines can also be caused by...
90% of greasy marks on cloths is due to scum build in the outer bowl of your loaders being the most vulnerable. prevention is better than cure. At least one hot wash a week on high level. If your machine is an early model one or two with a good bleach subject to manufacturers instruction...bleach is very cost effective and works well.
on Apr 09, 2008 | Bosch WFMC 3200 Front Load Washer
Why does my honda accord smoke reel bad
This is either worn valve stem seals or worn out oil rings. Have someone follow you if the car smokes more as you release the throttle on deceleration it is most likely valve stem seal if it smokes more on acceleration it is worn oil piston rings. If the smoke is white you have a blown head gasket blue smoke means burning oil, black smoke means too rich (to much gas reaching motor)
Jan 05, 2010 | 1991 Honda Accord
02 Stratus oil leaks when engine off (not when running)
Leaks oil from where ...from front seal ...valve cover gaskets ....rear seal ...oil pan ..if you find out where ..change the gasket from where it is leaking from
Jan 02, 2010 | 2002 Dodge Stratus
Black grease stains on clothes
trasmission top seal is bad
oil out means water in
Jun 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Sears Calypso washer is not draining. discharge pump is new and working. It looks like something is in the plastic tub blocking drainage. How do you remove spindle & SS tub to get at the plastic tub...
You really should replace the seals, gaskets and o-rings when you remove either the outer or inner wash plate or you have compromised the water tight seal for the U-Joint which drives the wash plate, and the washer will eventually fail completely (rust out the U-joint and brakes), from what the service manual warns. These units tend to eat small articles of clothing in the gap between the wash plate and the tub, if the seal starts to wear. According to the book, the gaskets and such must also be replaced when these plates are removed to avoid the inevitable seal integrity compromise that will ruin the unit's moving parts.
May 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Water collects in the seal....
Just replacing the gasket.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2009 | Kenmore 44102 Front Load Washer
Oil stains
Welcome to Fixya
My name is Huum,
You said, you have been getting oil stains on some of my clothes.
this means your washer has a leaking seal and oils is coming out onto your clothe.
Water is getting into the seal and bearings.
Do not waste any time. Get service out there right away.
If this is caught early you may have a chance to save a lot of money!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 03, 2008 | Maytag PAV2300 Top Load Washer
Clothes coming out with stains they didn't have - looks like oil/grease
Front load greasy residue ,
Due usually to much detergent in each load, use smaller amounts.
To much detergent degrades the rubber seals and gaskets and rubber seal also in some front loaders around the door too!
Over the life of a front loading washer the seal/gasket degrades
largely due to the chemicals in the detergent as well as bleach.
Most gaskets/seals get hard and brittle therefore the over the life of a front loading washer
the seal/gasket degrades largely due to the chemicals in the detergent as well as bleach.
....please rate this ....thanks
Sep 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ruining cloths, leaves black stain.
Black stains could only come from rubber part that is deteriorating. Need to check all hoses, rubber boot and at bearing seal.
Dec 11, 2007 | GE WCVH6260F Front Load Washer
GE WBSR3140DW Top Load Washer Logo
1,260 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
