Question about Garden
I have a 2000 PSI presure washer and I am looking for a replacement manual. this is the information on the pressure washer: Pressure wave 2020 C WVB 2000 PSI 2 GAL PER MINUTE 4000 C U 6 HP briggs & straten, DeWalt
  • 7,733 Answers
The presure washer head will not turn or will stop turner when engaged
The head probably needs some cleaning. I use a spray bottle of general cleaner. Then I'll shoot some wd40 in the head.
Jun 09, 2014 | Homelite Pressure Washer. 2600 psi 2.3 GPM...
Low presure oil
first thing check is the engine oil level.if oil level okay check oil pressure should be for the 4.2 engine oil pressure should be 12 psi @ 1200 rpm for the 5.3 oil pressure should be 18 psi @ 2000 rpm if oil pressure good problem in the oil pressure sending unit. if oil pressure is low problem faulty oil pump or worn crankshaft bearings if oil pressure low engine will have rod knock.make sure you are using correct oil viscosity if oil too thick you will have low oil pressure oil too thin you will loose oil pressure.
Nov 26, 2012 | 2004 GMC Envoy
What is the price and types of the pressure washers and where can i buy it?
Hi mary
About the price i think Mr JERRY is true
About the types there are many types like : -
- 2000 PSI Electric
- Gentron 2200 PSI Gas Pressure Washer
- Gentron 3000 PSI Gas Pressure Washer
- Gentron 4200 PSI
- 1600 PSI Electric Pressure Washer
- 2000 PSI Electric Pressure Washer
- 2200 PSI Gas Pressure Washer
And about the place you can buy these products, you can find many depots online like : -
http://www.generatordepot.us/pressure-washers.aspx
Thanks
Oct 30, 2011 | Garden
Sears 2600 psi power washer
there should be a low presure tip for dispensing wash cleaner or if you have an adjustable wand turn it to low presure setting also make sure the suction tube is open some have a adjustable filter...good luck
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
Can't find replacement recoil kit
What engine is on your presure washer? I really need a model number to give you the correct information.
If you have the engine model number you can look the engine up on the net at:
http://jackssmallengines.com/help.cfm
and find your recoil assy.
If it is just the rope that broke you can take the recoil to any lawn mower repair shop and they will repair your recoil by replacing the needed parts or replace the rope. You do not need to take the whole unit to the lawn mower repair shop. FYI a NEW honda recoil assy ranges from $32.00 - $68.00 depending on net source.
Thanks for using FixYa.
Kelly
Apr 16, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
Tire pressure optimization setting
Look for a sticker on the drivers door panel. It will tell you what pressure to set for the tires. The owners manual may also contain this information. It is normal for a radial tire to look a little flat.
Jul 31, 2008 | 2000 Honda Accord
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
