Question about RIM BlackBerry Curve 8310 Smartphone
JVM Error 547 Flash write failed ?? - RIM BlackBerry Curve 8310 Smartphone
    Problem Solver:
  • 13 Answers
there is no other solution than to reinstall the software. Let me know if you need instructions.
Regards,
BES Tech
Posted on Nov 10, 2010
4 Suggested Answers
  • 53 Answers
SOURCE: JVM ERROR 547, PHONE WONT COME ON AT ALL
FIRST CHECK WITH YOUR PHONE PROVIDER to see if you must use a special version of software ! If not proceed >>
BEFORE ANYTHING !!!! use the desktop software to backup your data on the BB (if you can) and save the file to the desktop. next go to https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4you need to download (use pull down menu)blackberry desktop software 4.6 and the Blackberry device software for your model phone. install the desktop software first then the device software.. this can take maybe an hour (not including the download time)
Posted on Feb 07, 2009
chiefmecha
  • 600 Answers
SOURCE: jvm error 547
It is important to have the following software installed on your computer (at home and at work if you can):
1 - Desktop Manager - Hopefully this is already on your computer, if not click here:
https://www.blackberry.com/Downloads...93E4F3BB068C22
2 - Device Software for your BBHere is the link for you to get the latest OS for your Blackberry
http://blackberryforums.pinstack.com...ll_models.html
3 – Java Commander – You can download it here:
http://blackberryforums.pinstack.com...d=5&linkid=452
4 - Backups – You should be creating a backup of your device data regularly, e.g., as often as you update your calendar and/or phone book, or at least once a month. If you do not already have a data backup, you are out of luck (SOL) as your data is gone.
STEP 2
The Process
From Pinstacker JTReeves:
You should be creating a backup of your device data regularly, e.g., as often as you update your calendar and/or phone book.
If or when you get a JVM Error 102/Reset message, do the following:
1. Connect your BB to the computer.
2. Run JL_Cmder
3. Choose option 5, wipe the device. This will delete all files - OS and data - from your BB. The BB screen will show JVM Error 507. This means the BB has no files installed.
4. Using Desktop Manager, reinstall your software. When you run the Application Loader, check all the available boxes.
5. When this process completes, restore your most recent backup file.
You should be back to normal, with the exception of having to reregister OTA or other 3rd party apps. Save their reg numbers in your Memo app so that you have them handy.
Posted on Dec 05, 2009
  • 43 Answers
SOURCE: white screen on my blackberry curve that's reading
That you will probably need to reinstall the OS. Try doing this through the Desktop Mnager. If it works great. If not then you will need to wipe your phone (try using JL Cmndr) and the reinstall the OS.
Posted on Apr 30, 2010
How to fix the error jvm error 547 on my bb 8100
all you need to do is to take it to a software engineer to flash it for you
Jan 09, 2011 | RIM BlackBerry Pearl 8100
Tip
How to fix blackberry phone errors by Updating the Firmware?
Most Blackberry phones encounter errors due to phone software failure.
Here are some problems and as this definition shown below.
JVM stands for JAVA VIRUAL MACHINE
* JVM Error 501: During memory management, freeing of resources from memory failed as a result of possible corruption
* JVM Error 517: The BlackBerry Device Software encountered unexpected data in a memory location which is used for normal operations
* JVM Error 535: Interaction with the file system has experienced a catastrophic failure
* JVM Error 547: While writing data to the file system, a failure was detected
* JVM Error 548: While erasing data from the file system, a failure was detected
Some can be fix by Hard reset,but most phone need to flash the frimware to be recover.
Here are the step by step procedure on how to fix your phone by updating the Firmware.
* You need a good working USB cable
* Battery is Fully charged.
1. Download Blackberry Desktop Manager and install it. : HERE
2. Download Flasher blackberry Tool : HERE
3. download & install flash file : CLICK ME
4. Delete the vendor.xml file located in c:program filescommon filesesearch in motionapploader
Open flasher blackberry Tool shown on this illustration
5. Go Next
6. You can see usb pin number if your phone is connected to your computer. go next
7. This is very important, don't forget check the box all apps you need and Go next.
8. Wait the application loader flashing in progress ...
9. you're almost there and wait when update is successfull ...
Done....
I hope this method simple helps you.
on Jul 14, 2011 | Cell Phones
I have balckberry Bold 9700. I have problem "JUM ERROR 102" Please help me.
i have the same phone. its JVM error 102 and you'll also get uncaught exception java.lang errors more than likely. its caused by a coruption in the software. its nothing you did, the software just failed. you can call your provider and do an exchange but it takes forever!! if you have a computer you can run the application loader and it will 100% FIX the issues. it saves all your info, wipes the old software, and reloads all the brand new software. this is from tmobiles website t-mobile.com/forums
Most JVM errors on a BlackBerry, can be fixed by simply reloading and updating your device software. For instructions on how to reinstall or upgrade your BlackBerry software, please see: HOW TO: Install New Software and Update (Application Loader) - BlackBerry®
There are some JVM errors that can not be fixed in this method, if you do encounter one of the below JVM errors, please call customer care at 1-800-937-8997 or 611 from a T-Mobile phone for further troubleshooting.
  • JVM Error 501
  • JVM Error 517
  • JVM Error 535
  • JVM Error 547
  • JVM Error 548
Didn't find an answer to your problem? Post about it in our BlackBerry Forums
Help us improve this article, please leave a comment.
Take me back to the BlackBerry Knowledge Base
***This link will show you how to reload new software with screen shots and a video!!!
http://forums.t-mobile.com/t5/BlackBerry-General-All-Devices/HOW-TO-Install-New-Software-and-Update-Application-Loader/ta-p/306005
***when this helps please give me credit and rate me appropriatlly, please!*****
Jan 03, 2011 | Cell Phones
White screen on my blackberry curve that's reading jvm error 547 flash write failed what does that mean
Dec 09, 2009 | RIM BlackBerry Pearl 8100
Jvm error 547
STEP 2
The Process
2. Run JL_Cmder
Dec 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Jvm error 547 flash write failed
Cause:
Some of the boot up file has got corrupted
Resolution:
Re-install the handset software using Desktop Manager
Jun 16, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
JVM ERROR 547
i can repair it...email me
Mar 30, 2009 | RIM BlackBerry Pearl 8100
Jan 13, 2009 | RIM BlackBerry Pearl 8100
Jvm error 547 blackberry 8320
try running app loader again but before you connect your phone up to the computer pull the battery out, then connect the phone, then put the battery back in. A lot of times it will force the connection to get established and then you should be able to run app loader.
Nov 16, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Curve 8310 Smartphone Logo
531 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
