Question about Toshiba Computers & Internet
Shuts down right after start up, shuts off. - Toshiba Computers & Internet
    Guru:
  • 832 Answers
Hello there!
You have to check your battery meter. Then try to remove the battery and plug-in your laptop directly to adapter without the battery. Just to make sure if its going to start up when you power up your system using your adapter.
If you need further assistance, please let me know.
Regards,
fossildude
Posted on Nov 10, 2010
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
Tip
Customize the Shut down button windows 7
Customize the Shut down button The default action of the Start Menu's Shut down button is to turn off your PC. If you want to use the button for another action, such as restarting your PC, you click the arrow to the right of the Shut down button and select an action from the drop-down menu.
What if you rarely shut your PC down completely but frequently restart it? You can change the Shut down button's default action to be Restart -- or Switch user, Log off, Lock, Sleep or Hibernate.
To change your default, right-click the Start button and select Properties. On the Start Menu tab, click the "Power button action" drop-down menu and select which action you want to be the default. Then click OK, and OK again.
on Jan 12, 2010 | Computers & Internet
How do i turn off windows 8
1. In Windows 8.1, from the Start screen, click the Power button and select Shut down.
If you can't see Start screen, point the mouse to the bottom-right corner of the screen, click Settings, then click Power, then click Shut down.
2. From the Start button, select Shut down or sign out and then Shut down.
Jul 08, 2014 | Computers & Internet
Turn off windows 8
Galant 95 backfires and shuts down at higher rpms
check ur plug wires they might be mismatched ...joe
Aug 29, 2009 | 1995 Mitsubishi Galant
I just bought a sony VIAIO today and dont knoiw hoiw to shut it down
1. Normal shutdown: select Start - Shut Down - Shut Down
2. System hangs: select Alt-Ctrl-Del and then Shutdown
3. If #2 doesn't work - hold the power button until the screen is dark
Hope this helps.
Aug 17, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
'04 vl800 shutting down (fuel?)
ITS FUEL QUALITY YOU NEED TO CLEAN OUT YOUR TANK FUEL LINES AND CARB AND USE HIGHER OCTANE FUEL
Feb 13, 2009 | 2004 Suzuki VL 800 Volusia
Computers & Internet Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
