Question about Nordic Track NordicTrack Treadmill, A2550
Belt is off center - Nordic Track NordicTrack Treadmill, A2550
  • 297 Answers
Tighten the rear adjusting bolts until the walk belt it tight enough to lift about 1.5 inches at the sides of the walk belt. After you do this, Turn the treadmill on to speed setting 2, and be ready to tighten the side that the belt is closest to.( if the belt is against one side, start with that side) Tighten only 1/2 a turn at a time and watch the belt start to move. It wont take much once it starts to move. Only tighten each side ( if necessary) dont loosen the bolts. Once the belt is in the middle, leave it alone. The belt is now adjusted. You may see it travel to one side, breifly, but it will return on its own.
Hope this helps
Posted on Nov 10, 2010
Where is belt for ul70120 found
Hi there! The belt for the Uh70120 can be purchased from Hoover.com directly or from an authorized service center. This unit takes belt number 562932001. Below you will find a link where you may go to purchase the belt, as well as a link to our service center locator.
http://bit.ly/1lzmUv1
Service Center Locator
Hope this helps!
Aug 12, 2014 | Hoover Vacuums
I have a life fitness next generation treadmill and the belt has slipped all the way over to the right hand side and is unusuable. How can I fix?
Belt adjustments are on the back of the machine on either side on the rails. Loosen both off first to slide belt over towards center. Then tighten slightly. Run treadmill on lowest speed and adjust from side to side until belt stays centered. After it seems to stay centered run treadmill on high to see if it stays centered and make small adjustment until it does
Jul 09, 2014 | Exercise & Fitness
Tomberlin Firefox 620 CVT Belt #
System should be Asymmetric from factory (belt flat on motor side, tapered on the other).
If you have a 6" Diameter Driven (lower) pulley and the Center Distance (shaft center to shaft center) is around 7-3/16" you need this belt: http://www.beltpalace.com/co20rebe1.html
If same Driven unit, but about 6-3/4" Center Distance, use this one: http://www.beltpalace.com/manco5959.html
or it's high quality Comet version: http://www.beltpalace.com/stens255-299.html
Oct 01, 2012 | Cars & Trucks
Water pump/timing belt on 02 volvo s60 turbo diagram
5-Cylinder Engines
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    Negative battery cable Engine stabilizer brace Servo reservoir Expansion tank Accessory drive belt Front timing belt cover Right front wheel Inner fender liner
  3. Turn the crankshaft clockwise until the markings on the crankshaft and camshaft pulley correspond.
  4. Turn the crankshaft a further 1/4 turn clockwise and then back again until the markings correspond.
  5. Remove the upper timing belt cover.
  6. Slacken off the belt tensioner center bolt slightly.
  7. Hold the center bolt still and turn the eccentric on the tensioner clockwise to 10 o'clock.
  8. Remove the vibration damper using Volvo counterhold 999 5433 or equivalent.
  9. Remove the camshaft belt.
To install:
  1. Turn all the pulleys listening for bearing noise. Check to see that the contact surfaces are clean and smooth. If the tensioner pulley lever or idler is seized, replace it.
  2. If replacing with a new idler pulley, tighten to 18 ft. lbs. (24 Nm).
  3. If replacing tension pulley, screw into place using the center bolt by hand. Ensure that the tensioner fork is centered over the cylinder block rib. Ensure that the Allen hole on the eccentric is at "10 o'clock".
  4. Install the camshaft belt over pulley wheel on the crankshaft.
  5. Install the vibration damper and tighten the center nut to 133 ft. lbs. (180 Nm).
  6. Install the timing belt in the following order:
    1. Around the crankshaft sprocket.
    2. Around the right idler pulley
    3. Around the camshaft sprockets
    4. Around the water pump
    5. Onto the tensioner pulley
  7. Carefully turn the crankshaft clockwise until the timing belt is tensioned. The belt must be tensioned between the intake camshaft pulley, the idler pulley and the crankshaft
  8. Hold the belt tensioner center bolt secure. Turn the belt tensioner eccentric counter-clockwise until the tensioner indicator passes the marked position.
  9. Then turn the belt tensioner eccentric back so that the indicator reaches the marked position in the center of the window and tighten the center bolt to 15 ft. lbs. (20 Nm).
  10. Press the belt to check that the indicator on the tensioner moves easily.
  11. Install or connect the following:
    Front timing belt cover and tighten to 9 ft. lbs. (12 Nm) Upper timing belt cover Accessory drive belt Servo reservoir Expansion tank Engine stabilizer brace. Tighten the bolts at the suspension turrets to 37 ft. lbs. (50 Nm). Tighten the engine bracket bolt to 59 ft. lbs. (80 Nm). Inner fender liner Front wheel Negative battery cable
    Fig. Timing mark alignment
11_15_2011_12_35_07_am.gif Fig. Belt tensioner
  1. Belt tensioner
    Fig. Timing belt installed
    Fig. Tension indicator at different temperatures
Nov 14, 2011 | Plumbing
I have a Proform 380 Treadmill. When the treadmill is on the belt rubs on the left side.How do I center the belt?
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
May 24, 2010 | Proform 380 CS Treadmill !
Center rear seat does not have a shoulder/lap seat belt
You should be able to go to the dealer and buy the center lap belts and can install them without having to by the seat just call your loacal dealer they can tell you how much thy are, less expensive than the seat.
Apr 21, 2010 | 2002 GMC Sierra 1500
My treadmill walking belt has moved to the right and slips.
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, Start unit @ 1.0 mph using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn to move belt to the right. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise or clock wise 1/2 of a turn depends on the tension that will be on the belt take your time and walk on it to feel the belt underneath you2_bing.gif Repeat until the walking belt is centered.
Feb 28, 2010 | Nordic Track NordicTrack Treadmill, A2550
Everything seems to work fine except a small slip in the track about every 30 seconds or so. Is there something that needs to be tightened?
The walking belt may be too loose. If you have made recent adjustments, lubricated, or had repairs, a belt can slip if not tightened. The belt can slip if you have too much friction or if the belt has been recently lubricated. If lube does not help your problem and you have exhausted all other possibilities, the walking belt is most likely worn out and must be replaced.
To adjust the belt: Less Belt Tension: turn both adjustment bolts on back of treadmill in a counter-clockwise direction. More Belt Tension: Turn both adjustment bolts equally in a clockwise direction. Center Adjustment (moves belt center to the left): Turn left-side adjustment bolt counter-clockwise. Center Adjustment (moves belt center to the right): Turn the left-side adjustment bolt clockwise.
An over tightened walking belt can raise the amp draw of your treadmill, contribute to seam separation on the walking belt, or both, so do not over tighten the walking belt.
You should be able to lift the belt in the center on the side by approximately 2” to 3”, if you cannot lift it by 2” to 3”, the belt is too tight.
Feb 20, 2010 | Nordic Track NordicTrack Treadmill, A2550
How to do you adjust the belt on a Pro form crosswalk 380? The belt is getting loose and I lost the manual.
Feb 20, 2010 | Proform 730 Folding Treadmill Model...
Nordic Track NordicTrack Treadmill, A2550 Logo
214 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
