Question about Mitsubishi MS-A09WA Split System Air Conditioner
Some times suctun line ice forming but gas is ok hy?
  • 81 Answers
Icing bad or just abit? its normal to have water on it if its icing under the black foam insulation you have a gas problem gas leak, or a fan not working
Posted on Nov 10, 2010
I have ice forming on copper line near compressor and there is a oily greasy substance on the compressor. What might be the problem?
the greasy dust is from a gas leak in the system and the oil is coming out with the gas
the ice forming on the pipe is the internal evaporation of the liquid gas
I suggest that a technician be called to repair the system
Oct 14, 2016 | Refrigerators
My split unit: indoor form ice below the filters time to time
you need a gas top up have an engineer to have a look its not a diy job
Oct 13, 2014 | Heating & Cooling
No ice formation in freezer but sometime ice formed on upper surface og freezer
the pathway might be blocked along the line thriough which the gas travels.
Aug 28, 2014 | LG Refrigerators
A/c runs fine for about 1 hour ,then cold air stops. go on roof and find that line from comp. is frozen and twice the size with ice.
Usually when the suction line frosts back to the compressor and forms ice that means you have plenty of gas in the system. So what ya do is clean the air filter and the evaporator as best you can. Make sure the fan inside is operating properly.
Jul 22, 2012 | Dometic Rooftop RV Air Conditioner
Ice forming on a line from the compressor and melting , ruining my floor
indicates low refrigerant gas, you will need a technician to top up the gas after ensuring there is no leak in the system
Aug 05, 2011 | Whirlpool Refrigerators
I have a 2005 Passat 2.0v saloon, just recently my car stated stalling on cold startup, it revs on then cuts out. This happen serval times, I leave it for a few minutes then it starts up fine and work...
I have seen allot of this in the recent cold weather, even with my Wife's car...
Most often it is caused by ice forming in the fuel line.
Try adding a can of DryGas (one other brand name is "Heet") to your tank. The results are not immediate, but eventually the ice will be gone.
If you can get your car into a garage (especially a heated one) it helps allot.
Most often, a fuel line ices up because a gas tank is not filled until nearly empty- try and keep your tank full in the winter!
Feb 01, 2011 | 2006 Volkswagen Passat
I noticed my lines for my a/c were freezing up, i had defrost on with heater all the way on foot /defrost??? any idea why?
by freezing up do you mean ice formed on the outside of the AC lines? Or did the freon gas flow stop?
Jan 18, 2011 | 1998 Ford Escort
Ice continually forming on bottom of upright freezer
you nead to clear the drain.when you clear the ice you nead to make sure that the drain is clear.a spider can build a nest in your drain line.if you remove the ice,you nead to clear the drain line with a hose.you nead to blow though hose and clear line.
Nov 18, 2009 | Ovens
ICE FORMING ON COMPRESSOR LINE MELTS FORMING POOL OF WATER ON FLOOR
indicated appliance is overgassed assuming fridge and freezer temps are ok
Aug 27, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Flat ice forms at the bottom of the freezer compartment
check your freezer door see if it (ajar) what you can do if you can unplug unit clar drain with hot water then get apiece of shave wire hook on the defrost heater and put in drain line 1/8 in the drain line put back wall back together and plug unit in
Apr 07, 2008 | GE Profile 21.6 cu. ft. Side-by-Side...
Mitsubishi MS-A09WA Split System Air Conditioner Logo
120 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
