Question about Brother HL 2140 Laser Printer
I can't get the HL 2140 to turn on. No power. It's wired up correctly and pluged in to a power sourse but the machine will not turn on.
Are you pressing the big button on the front that looks exactly like an on/off switch? because the real on/off button is small and black, and on the side panel by the back.
Posted on Nov 11, 2010
My printer HP ( HL-2140 laser ) print out a black sheet?
This will be the Corona Wire on the drum has broken. Replace the Corona Wire if you are technically minded or replace the drum unit if you are not.
Jan 10, 2015 | Brother HL 2140 Laser Printer
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
My HL 2140 squeeks loudly when I turn it on as well as when it is printing
it most likely has parts that are worn out and need replaced. you will need to have it serviced.
Oct 09, 2012 | Brother HL 2140 Laser Printer
My Brother HL 2140 laser printer is plugged in but will not power on. I've tried plugging it in to other outlets with no luck. Help!
Hi there!
First make sure that the printer is connected securely from the power outlet to the rear of of the machine. And press the on/off switch on the right side of the printer. The blue light/ go button should lit up.
Hope this helps. Rate if it works. Thanks
Mar 31, 2011 | Brother HL 2140 Laser Printer
How do i clean the corona wire for my hl-2140 printer?
Well the best solution for the corona wire is to change it. It is the best and safest solution.
If you need further details and assistance please leave a comment. Cheers
Aug 25, 2010 | Brother HL 2140 Laser Printer
HL-2140 Clean Corona wire Message won't go away.
you have to take out the drum and on top of the drum unit, there is a blue color plastic which can be slide from left to right... just slide a few times from left to right...that will clean the corona wire .
Jun 15, 2010 | Brother HL 2140 Laser Printer
If you are getting "clean corona wire" on your PC and the toner light on the machine is solid, you need to change your toner cartridge.
This is a bug in the brother software.
Thanks,
Pat
May 11, 2010 | Brother HL 2140 Laser Printer
HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
Sep 30, 2009 | Brother HL 2140 Laser Printer
Brother HL-2140 Error light is flashing
Try to unplug the power from the print, wait 1 minute then plug back in.
This may remove the error.
Sep 26, 2009 | Brother HL 2140 Laser Printer
Reset botton in this HL-2140 PRINTER
There isn't a reset button, try power switch.
Jan 14, 2009 | Brother HL 2140 Laser Printer
Brother HL 2140 Laser Printer Logo
1,379 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
