Central air fan will not turn on. Greens lights alternately flashing. Pulled power plug. Replugged power. Both green lights now flashing together
  • Anonymous Mar 31, 2014
    The green power light flashes but not working
  • 81 Answers
What brand and type is your unit. im assuming its a through wall/window unit ?
Posted on Nov 10, 2010
  • easy7 Nov 10, 2010
    This a Lennox central air unit mounted in my attic and the compressor is out side. After the posting I disconnected the unit from power again only I waited about 2 minutes and the problem was resolved. Thanks for the attempt.
Green light on tv trunes tv off. then green light gose off @ ON
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
Jun 17, 2012 | Televison & Video
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
May 30, 2012 | Mitsubishi WD Televison & Video
Installing Broan exhaust fan/light/night light model QTR070L. Am connecting with a single switch power source. Fixture has three whites, one blue, one black, one red and the ground (green). In what color...
Hi .. with only bone switch for this combo unit, the connections would be like this .. all ahites together with the romex white , all colors, red, black, blue with the romex black, all greens together IF you had more than one switch , then the red, black, blue would be connected separately to one switch eack and separately to a 4 wire romex from the switch to the combo unit.
Apr 17, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
CANON I350 DOES NOT PRINT
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Sep 17, 2009 | Canon i350 InkJet Printer
Epson C48 red and green lights flashing alternately
Only Solution is Re-burn printer firmware.
Mahesh DG, Pune
Sep 08, 2008 | Epson Stylus Photo 1280 InkJet Printer
Playstation 3 crazy fan problem
Its a power supply issue you might want to exchange the PS3 for a new 1 at www.sony.com
Rate my Solution Please
I tried my best.
Apr 30, 2008 | Sony Playstation 3 (PS3) Console
Bought a monte carlo ceiling fan. removed old fan and found 3 white and 3 black wires, plus grounds. Cannot figure out how to connect the unit up. breaker controls all ceiling lights in master bath,2nd...
Try this:
* All 3 black together, with black and blue from fan
* All 3 white together, with white from fan
* All grounds (earths) together, with all greens from fan
Apr 28, 2008 | Hampton Bay 24002 Ceiling Fan
Mitsubishi WSB55
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
33 = Air filter cover is open.
44 = DVI cable between FMT and Engine disconnected
Feb 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Flashing green light
Jan 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
