Question about American DJ Mister Kool Fog Machine System
I have a mister kool fogger and it barely has any fog coming out of it. the fluid in the line doesn't look like it's moving. ????
  • peterandl497 Nov 10, 2010
    yes, it was. thank-you !!!
    Guru:
  • 773 Answers
There is either a leak in the feed hose, or the pump is going bad.
Posted on Nov 10, 2010
Repair manual
I first tried to remove the mister but the way it is built make it impossible to take it apart without destroying the cauldron. So what I did was purchase another fogger for 20 bucks. [Found it on the web] It fits snuggly between the outside wall and the original mister. The wire went up her dress and out her hand that holds the stick. I used masking tape and taped the wire to her stick. then I painted so it was not as noticeable. I put the screen in the cauldron and you can't tell the there is a replacement. The only thing that is different is Now the mist has all different colors instead of just red. It is a easy solution
Oct 30, 2013 | Gemmy 5-1/2' Life Size Witch with Fogging...
Turned the fog machine on, all the lights come on- so electricity is getting to it- i havent used it for 5-6 weeks as I've broken my leg. The fluid is high, I switched it on, and it made no noise- nor...
Hello, Do you have the remote? Sometimes when they dont have the remote the unit starts to cry and it dosent want to do anything. Regarding the contact info for american dj they are only located in the U.S and so is there contact support. Here is there number. hope this helps
fo@americandj.com Phone: (323) 582-2650 Fax: (323) 725-6100
Jul 28, 2011 | American DJ Mister Kool Fog Machine System
Even with the output turned to maximum the fog is thin and dissipates quickly. I have followed the cleaning instructions within the manual and I am still having this problem. What else could cause this?
A common problem is the use of the WRONG fog juice. Make sure you use the manufacturer's suggested product. Make sure you have the correct voltage. Use of a very long extension or attempting to run on a dimmer box also would cause the problem.
Jun 16, 2011 | Elation New Elation Ice 101 Low Fog...
Is there an attachment available for 1/4" drip systems that will produce a circular spray pattern between 10 and 12 inches in diameter?
you could try a fogger or mister tip they produce a fin mist.. home depot had them.. you might want to ask one of there guys, i have a hard time finding them when i go to look.. jay.. the guy in Florida that repairs pumps in longwood
May 26, 2011 | Garden
American dj mini fog, I conected to wall, but the machine doesn't gets hot, and not make smoke, why?
There are two switches/buttons on top... You have to both turn on the unit and also activate it with the second button OR using a remote plugin box. The heater takes a bit of time to warm up internally. You will not sense much if any heat outside the unit... They take a few minutes to come on. Make sure you use approved "fog juice" in the unit.
Dec 18, 2010 | American DJ Mini-fog - 450 Watt Fogger Dj...
My "Mister Kool" Fog machine
What about the Mister Cool fog machine, you pose no question here.
Jun 08, 2017 | American DJ Mister Kool Fog Machine System
Shoots liquid not fog
you need to let it fully heat up first!
Nov 15, 2009 | Fountainhead/Burgess Prod Black Flag...
Machine seems clogged
Hello, i just finished a successful repair. i did have to take it apart, and there were springs and ss balls(at fog liquid pickup end that i unscrewed to give easy access to blocked pipe) and such so work where parts won't be easily lost and pay attention during disassembly. The problem with mine(several years old) was blockage in the metal line(pipe) that carries the fogger liquid. i used carborator cleaner and a compressor hose with low pressure. i sprayed in the cleaner and then put air pressure each way back and forth till it eventually yet suddenly cleared out then allowed unobstructed passage. then flushed it to clean it well. BE CAREFUL, it can suddenly spray the cleaner out, safety glasses saved me from a bad accident but my face and lips were stinging from the cleaner, and that was with the end facing away from me(but into a bucket and it bounced back at me). Anyway, reassembly took a bit but now it fogs great again. Mine might be a different manufacturer(burgess) but most likely the same basic scenario. Best wishes
Jun 27, 2009 | Fountainhead/Burgess Prod Black Flag...
Fogger does not produce fog
It is common for the nozzle to plug up. If it is brass, it will unscrew and can be cleaned with a very small drill bit.
May 31, 2009 | Fountainhead/Burgess Prod Black Flag...
American DJ Mister Kool Fog Machine System Logo
194 people viewed this question
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
