Question about Frigidaire Dryers
My dry wont turn on it just hums when i press start!
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 10, 2010
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
My dryer wont start. When i turn the button to start it, it hums but wont run.
something is jamming the drum of the dryer from turning... remove the casing and take a closer look. There may also have been something recently dried which may have come out and jammed the dryer drum. Try hand turning the dryer drum to see... it should freely revolve at least a little bit
Good luck with it
Ck
Feb 13, 2011 | GE DVL223EBWW Electric Dryer
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Dryer wont tumble
i think the belt is slipping bad on your dryer,,
what puzzels me is you say you can here the motor hum? is it a hum? or a buzz?? if its a buzz then its more likley to be the motor as its past its best and it needs if it needs a new motor as well, it would work out cheeper to buy a new tumble dryer
Nov 16, 2009 | Dryers
Ran out of gas and now wont start
Have someone turn the key on (engine off) pull gas cap and listen at the fuel tank filler tube for a humming sound for a few seconds fuel pump running,If you don't hear a humming noise check fuel pump fuses,if you hear pump running it is a good possibilty that the pump impeller broke from running dry and you will have to replace fuel pump.
Nov 15, 2009 | 2001 GMC Yukon XL
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't start
If you are getting s slight HUM when you press the start button,your motor is experiencing some problems. If you do not hear a hum, and after letting the dryer cool down for several hours, it suddenly works again, your motor has an internal short and is shutting itself down via the internal overload. If there is no hum of any kind, even after letting it cool off for a long time, then either there has been a failure of a part in the line such as the door interlock switch, the timer contact or there is a thermal overload in the back of the dryer, down by the blower, it is white in color and it has probably opened up.
Dec 14, 2008 | Roper Dryers
Frigidaire Dryer hums wont turn on
motor-overheated. you might make sure the vent is clean.
Jan 05, 2008 | Dryers
Dryers Logo
44 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
