Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
I put W 7 32 bit, but the video resolution is no good , can you hep me to get video controller? Thanks
  • 386 Answers
Hi Good day!!! Try to upgrade your direct X click here http://www.microsoft.com/games/en-US/aboutGFW/pages/directx.aspx if still bad maybe your graphic hardware is not compatible for windows 7, by the way what operating system do you use before you install windows 7?
Please reply if you have further problems i will assist you more
Thank you for using FixYa
Please accept if my solution helps you
Posted on Nov 10, 2010
I am using a compaq 1701 flat panel monitor. I installed windows Xp. The screen resolution is $4 bit color coz the driver is not installed. Looking for the driver for compaq 1701 flat panel monitor for...
The screen resolution and bit color is controlled by the video driver NOT by a driver for the monitor.
Install the correct video driver for your video card and you will be able to increase the screen resolution to over 1024 X 768 and bit color to at least 32 bits.
Jul 21, 2011 | HP Compaq 1701 17" Flat Panel LCD Monitor
Is the ati radeon mxm II 512mb card a reasonable graphics card? Thanks
I am not very sure which ATI you meant, but I assume myself as ATI Mobility Radeon HD 3650 MXM II Graphics Card 512MB, which is compatible with MXM II graphics slot Laptops. It's a good graphics card and it supports high Resolution. For your reference, I include the following descriptions about the Interfaces and their respective resolutions:
# Two integrated DisplayPort outputs
* Each supports 24- and 30-bit displays at all resolutions up to 2560x16001
* 1, 2, or 4 lanes per output, with data rate up to 2.7 Gbps per lane
# Two integrated 400 MHz 30-bit RAMDACs
* Each supports analog displays connected by VGA at all resolutions up to 2048x15361
# HDMI output support
* Supports display resolutions up to 1920x10801
* Integrated HD audio controller with up to 2 channel 48 kHz stereo or multi-channel (5.1) AC3 supporting Dolby Digital or DTS, enabling a plug-and-play cable-less audio solution
# Integrated AMD Xilleon™ HDTV encoder
* Provides high quality analog TV output (component/S-video/composite)
* Supports SDTV and HDTV resolutions
* Underscan and overscan compensation
# MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264/AVC encoding and transcoding
# Seamless integration of pixel shaders with video in real time
# VGA mode support on all display outputs.
You can also check out the full specifications here (Click Here).
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Dec 30, 2010 | Computers & Internet
Toshiba Windows Vista resolution problem
Depending on the version of A100 you have, 1280X800 may be the max resolution for your graphics card. Read the user manual for your specific model to see what the max resolution is, but usually, the video driver will lock out resolutions that your screen cannot handle.
If, for some odd reason, your screen can handle a higher resolution, try updating the video drivers.
Now to answer your other questions;
  • There is no 64 bit color mode; and if there was it would be redundant, as humans can't see that many colors.
  • 60Hz is fine and is probably the best your monitor can do.
Aug 07, 2009 | Microsoft Computers & Internet
Unable to ajust resolution
you need to update the drivers for your vga card. once you do that you can select your resolution. go to dell's website and put in the model of your computer they will provide you a support page link that you can download your correct video drivers for your operating system. once you do that, you are good!
Good Luck!
Ruben
Jul 19, 2009 | Dell UltraSharp 1908FP Monitor
Screen sizing
Your problem is that the correct video driver is not installed and therefore cannot use all the video RAM.(the XP version of the video driver won't work with Win98).
When you adjust to True color at a higher resolution it drops to a lower resolution because it has insufficent video RAM, but you will get a higher screen resolution at a 16 bit color because it requires less memory (video RAM).
Install the Win98 driver for the graphics card and then it can use the full video RAM at a higher screen resolution with 32 bit color.
May 01, 2009 | Computers & Internet
PC via DVI to D52W20
I'm using a component dongle from an ATI x800. Never have had a problem. My resolution is 1664x936. I noticed that this RCA auto formats the screen size with the DVI-D or component, so you'll have to make the adjustments via your video card. Windows display properties might not let you select that resolution, so hopfully your video card software will allow you to pick a resolution. It would not let me use any kind of 720p resolution only 1080i settings would work.
Nov 25, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Video conversion
Hello Andrew,
Even though the website claims Archos can play videos of DVD resolution it cannot play videos of such big resolution 800 x 480..To display the full DVD resolution, you would either have to buy the HD add-on plugin (presumably for $20 as it is not available yet), which allows resolution higher than 720x480, or to buy the MPEG2 plugin, which allows you to play a raw DVD VOB file...So also it plays videos of Square pixels,So try to reduce a bit of resolution to 720x480....!!!!...Better Reduce the Resolution of the video to 740 x 480 and the bit rate while Converting, so Your Archos can play the MOvie Completely and you can watch it...Also I hope the Embeded Subtitles in the movie(MP4) doesnt work for which you have to get a seperated Plug-in i guess...Thank you!!!...
Don forget to rate the solution..
Please post back for further assistance...
Good Regards!!!..
Jul 30, 2008 | Archos 605 Digital Media Player
Resolution 16-10
Your resolution is based on your video cards capabilities. If your still using the original on-board, integrated video I doubt if you'll be able to reach such resolution. Open control panel, open Display. Click the Settings Tab. You will notice Screen resolution & there is a slide bar. Sliding the bar to More will increase the resolution. You'll see what the max is for your video card. As to your LCD monitor it's max resolution is capable of reaching 1680x1050. Keep in mind the word " capable ".
If you need that kind of resoluton you'll need to find a AGP video card that can go that high.
Please vote.....
Jan 30, 2008 | Computers & Internet
Widescreen resolution...
Every video card has it's max resolution. To see what your max is for the d530, if your running a version of XP. Open Control Panel. Open Display. This will open Display Properties. Click the Settings Tab. Listed there is screen resolution, sliding the marker all the way to More will give you your Max resolution. I have a high end video adapter & my max resolution only goes to 11280x1024. You may have to contact HP/Compaq. The link listed contains updated drivers for the d530 but there is a bunch listed because each d530's have different internal devices.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316715&prodTypeId=12454&prodSeriesId=316713&swLang=13&taskId=135&swEnvOID=1093#11360
You can chat with HP/Compaq at this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/ContactHP.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713
This is your best shot! Good luck.
Please vote...
map
Jan 29, 2008 | HP Compaq Business d530 Small Form Factor...
Computers & Internet Logo
52 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
