My computer just had gotten a black screen when i turned it on an i used task manager to get around it to ask how can i fix it?
    Habit-Forming:
  • 146 Answers
Try luanching a new task from task manager it should open a run window then paste the following
explorer.exe
then click run and see what this does for you hopefully it will launch windows
hope this helps and good luck the problem and by the way don't forget to vote or rate this solution
Posted on Nov 10, 2010
Black screen enter password
after typing your password and once the screen goes black again press [ctrl+shift+esc] this will open task manager
then click file > new task (run)
and run explorer.exe.
your desktop should open up
Jan 02, 2014 | ASUS Computers & Internet
How to fix black screen problem on my hp desktop Compact 6000 pro
1) Restart your PC
2) Logon and wait for the black screen to appear
3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this)
4) Press the CTRL, ALT and DEL keys simultaneously
5) When prompted, Click Start Task Manager
6) In Task Manager Click on the Application Tab
7) Next Click New Task
8) Now enter the command:
"C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com/download.asp?GRAB=BLACKSCREENFIX"
Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it.
9) Click OK and your browser should start up and begin the download process
10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue.
11) Now restart your PC and the black screen problem will hopefully be gone
Oct 30, 2012 | HP Compaq d530 SFF PC Desktop
Aftr i start n log onto my pc... I can see d mouse but d entire screen is blank!!! Pls say what to do
We wish you a merry Christmas and a Happy New Year.
Which is the operating system?
What exactly happens when you start the PC?
Is it Blinking cursor with a black screen?
Then its black screen error.
Firstly, there appears to be many causes of the black screen issue. The symptoms are very distinctive and troublesome. After starting your Windows 7, Vista, XP, NT, W2K, W2K3 or W2K8 PC or server the system appears normal. However, after logging on there is no desktop, task bar, system tray or side bar. Instead you are left with a totally black screen and a single My Computer Explorer window. Even this window might be minimized making it hard to see.
If you have these symptoms you can safely try this for free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below:
1) Restart your PC
11) Now restart your PC and the black screen problem will hopefully be gone.
Hope this helps.
Cheers!!
Dec 31, 2010 | HP Pavilion dv6000z Notebook
My c700 turns on and all but nothing shows up it runs the background lights turn on but its just a black screen
Restart your PC
Next Click New Task
Now type the command all in one line and precisely
If you have problems you might have a burned out backlight or problem this fix doesn't cover though it covers most of the reasons this happens.
Good luck
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me
as well. Thank you.
Nov 26, 2010 | Compaq Presario 700 470024-192 Notebook
My back ground is black and in bottom right corner it says did not pass windows validation may be a victim of software conterfiting
It's a long shot but try this:
1) Restart your PC
Good luck
Oct 15, 2010 | Computers & Internet
I'm trying to change the screen resolution while running windows 7 because I have no desktop showing on my monitor
If you have these symptoms you can safely try our free Black Screen Fix. It will fix the most common cause we have seen of this issue. Running the fix program is easy under normal circumstances, simply download with your browser using the link above and run the program. However, if you are trying to do this from the PC which has the black screen it is a bit more tricky. In these circumstances follow the procedure below: 1) Restart your PC 2) Logon and wait for the black screen to appear 3) Make sure your PC should be able to connect to the internet (black screen does not appear to affect this) 4) Press the CTRL, ALT and DEL keys simultaneously 5) When prompted, Click Start Task Manager 6) In Task Manager Click on the Application Tab 7) Next Click New Task 8) Now enter the command: "C:\Program Files\Internet Explorer\iexplore.exe" "http://info.prevx.com/download.asp?GRAB=BLACKSCREENFIX" Note this command assumes that you are using internet explorer as your browser, if not substitute your browser path and file details for those of iexplore.exe or use the Browser option of Task manager to locate it. 9) Click OK and your browser should start up and begin the download process 10) When prompted for the download Click run, the black screen fix program will download and run to automatically fix the issue. 11) Now restart your PC and the black screen problem will hopefully be gone.
Oct 11, 2010 | Computers & Internet
My Sony Vaio VGN-NS110D Laptop computer won’t boot up, it cycles through to a black screen with the mouse pointer there which I can move. Apparently this is called the ‘black screen of death’! I can’t do...
Try these 1) Shut down the system 2) Remove the battery 3) Hold down the power button for say 2 minutes 4)Put the battery back 5) Boot the system
If you still hit the black screen with a cursor: 1) Wait for 2 mins at the black screen 2) Just type in your windows password (if you don't have one hit enter) and press enter 3) Wait for another 2-3 mins 4) Hit Alt Ctrl Delete and go to task manager (this time it should take you to the task manager) - fingers crossed LOL 5) Now do new task - explorer.exe
Hopefully you should be back in action.
Note, this is a work around and for a permanent fix either try and clean your system (check for viruses) or reinstall the system. Hope this helps.
Oct 07, 2010 | Sony Computers & Internet
When I try to boot up windows Vista I get black screen
Looks like its an infection to me.
When you get to the black screen and you are able to move the mouse, try this:
Press Ctr+Alt+Del, a message will pop up.
Select Task Manager
A Task Manager window appears.
Click on File and choose New task (run)
Type: explorer.exe
Press the enter key.
You should be able to see your desktop again.
Once there, use a combination of antivirus, spyware, troyan horses solution of your preference to get rid of it.
Don't forget to rate this answer if it helps
Dec 04, 2009 | Acer Aspire 5610-4648 Notebook
Task manager problems
get a start up manager program to stop the processes you dont need that will make it not run so much at start up and your computer will run faster and if you try to end one of the processes that the operating system needs it will tell you and not let you do it so just mess around with it and see what you dont need then you can stop it at startup from running
May 30, 2009 | HP Compaq Presario SR1810NX PC Desktop
Computers & Internet Logo
Alun Cox
k24674
