Question about Husqvarna Husky 145
DO YOU HAVE A MANUAL FOR A HUSKY 2222. IT IS A VERY OLD MACHINE.
I need an extension table for my Husky 170 Sewing Machine.
Ebay or Etsy... sometimes has "parts machines" or just parts.
Mar 19, 2013 | Husqvarna Husky 170
Problem with a husky lock 340 serger. Wheel on right very stiff and foot pedal doesn't engage machine. Just makes a power noise but doesn't move the machine? What can I do.
My Bernette did exactly the same thing as you describe and when I took it to the mechanic there was a gear right inside that had split on the main drive path. It was a nylon gear and it had cracked right through the middle - my machine was about 12 years old at the time.
After one store advised I junk the machine, I then priced the part from Bernina head office, spoke to another mechanic and he was able to send my machine to another mechanic he knew who could pull the thing apart quicker because he'd done the repair before. I was warned it would cost $270-350 but I love the machine so said go ahead.
I'd suggest you take your husky to a local husky dealer for a quote on this, it does sound similar.
Mar 17, 2011 | Husqvarna Sewing Machines
I need a new manual for my husky 145. Where can I
The manual for your machine is probably out of print. If you call 1-800-474-6437 Husqvarna may be able to get you a photo copy of the original owners manual.
Sep 11, 2009 | Husqvarna Husky 145
Help for Husky 165 by Husqvarna Viking
I suggest that you visit the Husqvarna web site and put your model number in the serch, there is a lot of info there. Here is a link to the site.
http://www.husqvarnaviking.com/us/
good luck
May 15, 2008 | Husqvarna Husky 165
Husky 145
Usually when a machine is totally jammed, it's either (a) because a bunch of upper thread has gotten jammed into and around the bobbin assembly so thoroughly that the assembly can't turn at all, or (b) the needle is jammed down the hole so thoroughly that nothing moves.
If both of those places are clean and empty. . . then "Never mind!"
May 01, 2008 | Husqvarna Husky 145
Husky 165 - won't do a basting stitch
Set the machine to its longest stitch length, put it in the warmest room in your house and in the sun if possible. If the stitch gets longer when the machine is warm it needs to be cleaned and lubed so that the stitch length mechanism moves freely.
If the lube in the machine is getting old or is nonexistent, the reverse button may be depressed and appear to return to its original position, when released, but the mechanism inside the machine only returns part of the way causing the length to be shorter than normal. Heat often masks this problem allowing the mechanism to move.
Nov 12, 2007 | Husqvarna Husky 165
Sewing Machines Logo
113 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
