Question about Stairmaster 7000PT Nautilus Stepmill
I was recently called out to fix a 7000PT Stairmaster that was knocking. I isolated the knock to the transmission. I replaced and tested. Everything seemed fine. After a few days, the guy called back because lightweight females can not use the machine (there is too much resistance). I replaced the alternator and relay board and tested. Again, fine. Level 1 is slow and level 20 is running.. He called back the next day. Same thing. Lightweight females can't use it as it has too much resistance. I have tried to adjust tension on the drive chain, the poly v belt, as well as replace the alternator and relay board. The resistor ohms fine and it passes all tach tests and alternator tests. Any suggestions?? I'm lost..
  • Stairmaster Master
  • 918 Answers
This machine works off of gravity and requires a minimum of 120 lbs to function correctly. So without knowing what "lightweight females" is exactly, I am assuming they weigh less than 120 lbs.
Stairmaster Stepper 7000PT Stepmill Parts Transmission SPORTSMITH net
Posted on May 21, 2014
5 Suggested Answers
Marco Darko
  • 3 Answers
SOURCE: Stairmaster 4000pt pedals lose resistance during workout
places to check.
http://www.mindbites.com/lesson/8320-diy-stair-master-4000pt-pedal-drop-or-slip-diag
Posted on Jul 26, 2010
  • 48 Answers
SOURCE: When my wife uses stairmaster
hi
just check the speed of unit if she goes faster than when she was on level 17-or 19 it is ok
if not calibrate the tension but i think it is always feels like this
let me know
Posted on Nov 23, 2010
geo5734036
  • 528 Answers
SOURCE: When my wife uses the
The problem may lie in your wife's low weight - she just doesn't have enough weight to move the stairs at that resistance ( my wife weighs 100 lbs and can't get it to move at a high level). If she can hold some weights in her hands and have ankle weights on, she will be able to move the steps faster.
Hope this helps!!
Posted on Dec 10, 2010
jyackle5
  • 8197 Answers
SOURCE: My Stairmaster 4600CL is stuck
What has happened is the control panel is bad and you need to replace it.
Good Luck
Posted on Jan 07, 2011
The buttons on the console don't work. Can't change levels
If the buttons are not reacting, it could simply mean that the overlay/keypad is worn out. The following link will take you to a few of the options available for your model. Stairmaster Stepper 7000PT Stepmill Parts Transmission SPORTSMITH net
Dec 09, 2015 | Stairmaster 7000PT Nautilus Stepmill
My stairmaster will not rotate
Check the following video out for some troubleshooting steps regarding this issue.
Dec 19, 2013 | Stairmaster Stepmill 7000 Pt
Belt slips off stairmaster stepmill
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
There are a couple of different belts available for this unit. The following link will take you to the parts available for your model.
Apr 06, 2013 | Stairmaster Stepmill 7000 Pt
Stepmill 7000pt is free spinning and has no resistance.
How to Test the Relay Board on Stairmaster 7000PT Stepmill How to Test Relay Board of a Stairmaster Stepmill 7000PT Disconnect power from the machine.
Disconnect the main cable from the relay board J1 terminal. Main cable should remain disconnected for the duration of the relay board tests.
With the Power ON, place a jumper wire across the GND/BLK and RLY/RED test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Relay LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and FLD/BRN test points. (Ensure jumper wire only makes contact with the designated test points.)
  • Verify that the Field LED is lit. Remove jumper wire.
With the Power ON, place jumper wire across the +/WHT and with the other end touch the ALT/C, FLD/NC, and RES/NO.
  • Verify that the Field LED lights.
If any of these jumps fail, replace the relay board and or power supply. Stairmaster Stepmill 7000PT Electronic Testing of Relay Board
The second link will take you to the service manual. Starting on page 13, you will find some more valuable information on the relay board. Last link will take you to a video on how to test the alternator
Video about Performing Jumper Test on Stairmaster Alternator
Mar 12, 2013 | Stairmaster 7000PT Nautilus Stepmill
My Stairmaster 7000PT has no resistance past level 10 or 11?
This could be caused by worn alternator brushes. The following link will take you to a video on testing the alternator. If the alternator checks out, you may be dealing with a faulty display console.
Feb 06, 2013 | Stairmaster Stepmill 7000 Pt
Stepmill has no resistance when starting
First thing you'll want to do is check the alternator brushes. Here's a link to the different types offered for the Stairmaster 7000PT:
Repair Parts for Stairmaster Equipment Batteries Springs Belts Chains...
If the brushes look like they are in good condition you can also test the relay board. This link will take you to the procedures for checking the relay board:
Nov 06, 2012 | Stairmaster Stepmill 7000 Pt
My stairmaster 7000pt step is grinding and slipping
most likely your gear reducer (transmission ) has stripped and wii have to be replaced . call glide fitness products in santa ana california 1 866 637 4600. they will sell you a new one for about $180 or send in your old one and they will send you a rebuilt one for about $75 note shipping is extra
Jan 28, 2011 | Stairmaster 7000PT Nautilus Stepmill
Stairmaster 7000PT Nautilus Stepmill Logo
279 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
