Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore Washer/Dryer Does Not Drain. Please Help!
My Kenmore stacked Washer/Dryer does not drain the water at any cycle. The timer ticks but the water does not drain when it is meant to. Please help.
Thank you!
Best Regards
  • talktall Jun 23, 2008
    my kenmore stackable will not spin nor does the timer click it washes fine but doesnt spin out. i havent even started to fiqure it out i dont know where to start.
  • danielunitis Jun 25, 2008
    My Kenmore stacked washer / dryer does not drain water at any cycle. The timer clicks, but the water does not drain whwn it is meant to.
    Thank You
  • 1,294 Answers
Check out your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Some connect to sink, fine. Snaking out your standpipe would be good too.
If the above fails, check to see if your pump is blocked. Pl rate if helped.
Posted on Jun 17, 2008
Water won't drain from to change pump.everything else works fine. nothing pluged.
Does water drain when washer goes from wash to rinse or is it just at the end after rinse. It could be a switch on the cycle timer not working if it doesn't pump out at all. If it doesn't pump out at only the end maybe one of the cams on the timer that makes the switch to dump water is loose or broke.
Dec 30, 2014 | Kenmore 94702 Front Load Stacked Washer /...
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Sometimes when I turn the washer on; it continues to run the water without filling the bowl. Seems like the washer thinks its in rinse mode.
Check your drain the drain hose must be higher that the tub or it will run down the drain.
It must be going down the drain or you would have water all over the floor If the water is coming in it has to go somwhere. In rinse cycle it should stay in the tub until the timer kicks it into drain and spin.
Sep 14, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable mod number 417.94802301
check your lid switch. if your lid swith is bad, it will fill and agitate, but will not pump or spin. therefore it will not go into rinse cycle without being able to pump out water. some lid swithes control the agitation also (usually frigidaire and older maytags), but i doubt yours does. you can check the lid switch for continuity while opening and closing the lid with a meter
Apr 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer / Dryer WON'T DRAIN
Did the unit ever drain? If it did, has anything changed?
Make sure the drain hose in back has not pinched (unit slid backward against the wall, pinching the hose.).
Motor is two speed, and if it's not kicking to the high speed, then there may be a timer problem.
Jan 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
If motor runs or sounds like it is trying to run, you have a sock caught in the pump. If no noise at all you have a bad lid switch
Jun 07, 2007 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
149 people viewed this question
Sal De
 Brian Main
Brian Main
