Question about Motorola Walkie Talkie 2-Way Radio
What channel should i set my motorolla walkie talkie to get the best distance? It seem not to wok beyond 1/4 mile on channel 3.
    President:
  • 2,761 Answers
You didn't mention a model number, so I don't know if your radio is an FRS or FRS/GMRS model. GMRS channels have more power output than FRS does, but GMRS also requires a license for operation. Other than that, the frequencies are so close together that there is no distance advantage gained by changing channels. The manufacturer's distance claims on these radios are pure advertising gimmicks - the radios are line-of-sight only, so if there's anything between the transmitter and receiver, the signal will not get through.
Posted on Nov 13, 2010
Do you leav the cobra micro talk walkie talkies on when charging
Also, never transmit with them in the charging cradle. I know, lots do but you risk ruining the radio beyond repair.
Dec 26, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
Uniden walkie talkie
What is the condition of the batteries? Try it with new ones and if you still have this issue, you need special equipment to test the output and sensitivity of the transcievers.
Mar 14, 2014 | Radio Communications
Two sets of Motorola Walki Talki radios will not communicate.
In addition to the channel and privacy codes, some Motorola two-way radios have a feature called Eavesdrop Reducer where you have 3 scramble settings available; perhaps you have this set on one of sets of radios but not the other. It should be something like that because otherwise there is no reason that by setting the radios to the same channel and privacy code they wouldn't be able to send/receive to each other.
Nov 24, 2013 | Motorola Walkie Talkie 2-Way Radio
I bought walkie talkies with 56 km radius and yet we are lucky to reach each other after approx. 1 mile,any idea why we don't get the range
You do not mention the particular model of Motorola, so this answer will be generic in nature. Some Motorola TalkAbout radios have been factory programmed with a few GMRS repeater frequencies. These channels require the use of a repeater tower, which will 'repeat' what you say over a greater distance. It is possible you have this type of radio. Check your user guide, and then set your radio to the appropriate channel for the repeater in your area.
Radio-to-radio without the use of a repeater you can expect up to 2 miles line-of-sight out of most handheld radios. This distance is reduced by obstacles such as buildings, trees, etc. inbetween the radios. It can also be reduced if you do not hold the antenna of the radio perpendicular to the ground.
Best regards.
Jan 19, 2012 | Motorola Walkie Talkies 2-Way Radio
What is the range for distance for my bellsouth walkie talkies model 2231
The manual says:
Channels Available - 22 Channels
Output ERP Power (TX) - 0.5W (FCC Maximum)
BatteryLife - 30 Hours (typical)
Range - About 2 Miles
Jan 16, 2012 | BellSouth 2231TE (22 Channels) 2-Way Radio
I can't get my walkie talkie to go it's full 20 miles its only reaches maybe 3 miles or so it dont make any scence to me. also how can i comunicate with cb's in semi's
The distance claims made by FRS/GMRS radio manufacturers are fairy tales. The frequencies that these radios operate on are line-of-sight only, meaning that ANYTHING between the radios (buildings, hills, trees, etc.) will block the signals. Unless you're transmitting from one hilltop to another, with nothing between the two, 2 to 3 miles is the maximum effective distance for any of these radios.
On your other question, FRS/GMRS radios and CB radios operate on different frequencies bands, so you cannot communicate between the two types of radios. In order to communicate with CB radio operators, you will need a CB radio.
Bill B
Listening in since the 60's
Sep 22, 2010 | Cobra PR 4200 WX (22 Channels) 2-Way Radio
Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Oct 23, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Nextel i850 can't receive calls
  • may be the walkie talkie can recieve signals only to an certain distance,so it may be due to the signal problem........
  • if the reciever is beyond the permitted distance it loose its frequency...........
  • or else the person who is calling walkie talkie might not hav signal in that area.....
  • and if the walkie talkie does not recieve any signal then the receiver component present inside the walkie talkie might be damaged.........
  • and if it does not reply to an signal transmitter might be damaged..........
  • i hope my answer would be sufficient for u.....thank u......
Sep 10, 2008 | Motorola Mobility i850 Cellular Phone
Radio Communications Logo
261 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
