Question about Proform Crosswalk 500 Treadmill
I PROPPED UP MY PRO FORM XP CROSSWALK 580 TREADMILL TO CLEAN UNDERNEATH AND I CAN NOT FIGURE OUT HOW TO LOWER IT?
  • 297 Answers
There is a knob about halfway down or up, depending on how you are looking at it. You need to lift up or push up a little bit to take the weight off the locking pin, as soon as the weight is of it should pull out about 1/2 of and inch. Be careful ALL the weight of the walk deck is now in your hands. Be prepared to lower it, and use your second hand immediatly anfter you pull the locking pin out. After the walk platform starts to come down, let go of the locking pin, it has a spring to pull it back, but the pin only fits in ONE hole in the prop rod, so it wont grab on the way down. Some treadmills have a dampening shock to allow the lowering of the walk deck slowly, and some do not. So again BE CAREFULL, this could hurt you if it falls on you.
Hope this was helpfull
Posted on Nov 10, 2010
Why won't my treadmill incline or decline?
Hi there, checked both upper and lower bolted connections, and check that lift motor hasn't cracked and frame is intact with no blockages to a possible scissor arm-lift assembly underneath the unit ? If this all checks out, maybe a small gearbox on the lift motor failed internally. Good luck.
Feb 02, 2015 | Proform Excellent Condition Pro-form 400e...
No lights on the top panel of Treadmill Pro-Form 345s
1) replace the old batteries by new ones. clean the contacts batteries very well
2) tight the ribbon cable for keypads and clean it
3) tight the upper connector vs lower connector
4) adjust the REED switch, see the diagram clean it, test for open or faulty and tight the connector.
Jan 22, 2013 | Proform Exercise & Fitness
Does not go all the way up or down
PleaSE run THE SOFTWARE CALIBRATION, for easy diagnose, troubleshooting and fix it.
Lube the elevation motor, see the diagram attached.and proceed
God bless you
Jan 07, 2013 | Proform XP CrossWalk 580 Treadmill
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
Pro-Form Crosswalk 395 - Incline goes up and down with no tread movement. Calibration doesn't work - only on display.
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
Sep 29, 2012 | Proform Crosswalk 395 Treadmill
My pro form 580 si won't reach max speed. Why is
Dear Sir:
Adjust the speed sensor very weel see the diagram attached, tigh the connector wires very well, and clean the s. sensor very well.
2) Run the software calibration for easy diagnose , fix it, and trouble.according with your manual instructions.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Apr 03, 2012 | Proform Exercise & Fitness
Describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
May 31, 2010 | Proform Exercise & Fitness
My Pro Form 580 XP slows down suddenly while on, and speeds up again almost making me fall off of it. Anyone know why this could happen? The manual is no help.
If you have not ever lubricated the running deck then I suggest doing so . What happens is that the lack of lubrication will tend to make the belt drag thus slowing down the belt making the motor control board to try to compensate the drag.
Apr 21, 2010 | Proform Crosswalk 500 Treadmill
Jerky treadmill
Please check out this tip I wrote. Please let me know if you need anymore help.
Apr 08, 2010 | Proform Crosswalk 500 Treadmill
Pro-Form Crosswalk Plus Treadbill back leg extension
iconservice.com has free pdf downloadable manuals for proform.
Nov 12, 2009 | Proform Crosswalk 500 Treadmill
Proform Crosswalk 500 Treadmill Logo
1,735 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
