Question about Refrigerators
Cooler works well. Refrigerator is warm (53 F) even though temp control is cranked to right. Have had this problem before. Ended up soldering new capacitor at c2 position in the control unit that is located in the top right of the refrigerator. This worked for about a year but problems have returned. Soldered in new capacitor. It stayed cool about a week and is now as I described at the beginning of this note. Any ideas?
    President:
  • 1,891 Answers
The cap is only hepling with a poor power supply to the comp . so ck the comp relay and start device . this is i think where the problem is .. hope this helps mm
Posted on Nov 10, 2010
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
My refrigerator works for about 8hours, then warms up even though you can hear it running.
probably have refrigerant leak/faulty compressor/temp control or sensor.
Check the temp sensor little pipe is not caked with ice ..
turn off refrigerator and let it defrost even if it is frost free..
some fridges have an auto defrost cycle..could be it is doing one?
May 29, 2012 | Frigidaire Refrigerators
The overall refrigeration has deteriorated - the freezer is better than the regular compartment, though not as strong as it needs to be. the regular compartment is barely cooler than room temp.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 04, 2011 | Refrigerators
My refrigerator temperator does not seem to be cooling, when I turn the temp control to colder the refrigerator does not seem to get cooler, but the freezer will
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 28, 2010 | Kenmore 64802 Top Freezer Refrigerator
The refrigerator is not getting cooler even though its turned on and the temp is placed on cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 22, 2010 | Maytag MSD2756G Side by Side Refrigerator
Tru GDM-47 cooler evaporator icing up.
possible bad defrost timer,or control on an off is bad,were you adjust temperature...thermostat from 30 to 65.00 dollars....possible there is leak or unit is under or overcharged..more than likely under charged...possible defrost heater is not working...good luck..michael doctor airr appl.repair..service tech..843-384-8474...call if need additional help ..its free..
Mar 27, 2010 | True GDM-47-RL Refrigerator
650 sub zero fridge on 54 says needs service... everything warm f
Hi!! looks like you have a seal system problem..First make sure that the condensor motor is on and the compressor and indoor evaporator fan if yes..You have a seal system problem..
Jan 04, 2009 | Sub-Zero 650 / O Bottom Freezer...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
If you're handy with a soldering iron, it's possible to 'trick' the fridge into cooling down a few more degrees.
Long version:
If you open the door to the fridge, on the right wall near the bottom is a small plastic grate. You should be able to pull this straight out from the side wall. There is a temperature sensor attached to the back of the grate. Unplug the sensor. (The fridge will then give you a very annoying error beep and display "EE" on the readout. Pushing the °F-°C button stopped the beeping.) This sensor will change resistance with temperature. (The lower the temperature, the higher the resistance) I was reading a resistance of about 3700 ohms at 43°F and 2460 ohms at 68°F. Throw in a rough assumption that the response is linear and it works out to almost 50ohms/degree. In order to 'trick' the fridge into cooling down more, you need to drop the resistance. I was aiming for about 6 degrees cooler. Assuming the resistance response was linear, 6 degrees cooler would give me about 4000 ohms from the sensor. By jumpering a 50000 ohm resistor (yes, 50K ohm) in parallel with the sensor, I should get about 6 degrees cooler. I did the soldering, plugged the sensor back in, and ended up about 8 degrees cooler. Two days so far, everything appears good and the beer is cold.
Short version:
Put a 50K ohm resistor in parallel with the temperature sensor behind the grate on the inside right hand wall.
The temperature read out will be inaccurate forever after though. But then, I just want cold beer, my wife wants cold water, and the kids want to play with the cool blue light. I don't care what the number on the readout is.
Oct 03, 2008 | Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
