Question about Dell 968 All-In-One Printer
1. I hit "print" for a document. 2. Immediately
  • 340 Answers
Go to start, devices and printers and in here you will see a few options. make sure that there is a check mark next to your Dell all in one. There will most likely be a fax, document writer and scanner as well listed in here. If you do not have a check mark next to the one that says all in one, right click on it and select set as default printer. Try to go back into your document and print. Try this and let me know what happens.
If you found this helpful please leave a rating, thanks!
Posted on Nov 10, 2010
The printer's print que says it is "deleting"
I know how annoying this can be. Try the following and let me know if it worked for you:
1. On the taskbar, click Start, and then click Run.
2. Enter the following:
net stop spooler (and hit enter)
3. Delete all files in the following folder:
C:\Windows\System32\Spool\Printers
4. Once the spool files are deleted, start the spooler again:
5. On the taskbar, click Start, and then click Run.
6. Enter the following:
net start spooler (and hit enter)
Sep 30, 2011 | Office Equipment & Supplies
Hello, i have 2 questions: 1- i need to know if there is away to convert "Arabic protected PDF book into DOC " 2- i need to know is there is away to supervise my team while the are dealing with...
PDF is the only document format that typically allows you to view the file, instead of editing with many means like data encryption techniques, passwords and local restrictions. Due to these actors, users prefer to convert PDF to Doc format so that they can access and make changes to the data. Once converted to Word format, files become open for modification, editing, printing, copying and extracting information. Using Doremisoft PDF to DOC converter is the most effective method to convert PDF to Doc with utmost ease and accuracy.This is an easy-to-use and efficient PDF to Word utility that converts PDF to Word DOC file with great precision. Good Preservation PDF Converter preserves all the elements of original PDF files, such as text, hyperlinks, images, layouts, tables, columns, and graphics. The best aspect about this utility is that as a user you can also convert password-protected PDF file. During the process of PDF to word conversion, the software prompts the user to enter the password. As a result, it is very important that the password of the PDF file must be known for PDF to Word conversion.Key Features of PDF to docx converter:
1.Support all Windows platforms, Windows Server 2008, Windows 7, Windows Vista, Windows XP, Windows 2003 and Windows 2000 2.Provides complete support to the conversion from encrypted PDF files and password protected documents 3.Preserves the Text, Pictures, and Layout even after the successful conversion of file from PDF to Word DOC format 4.Supports Unicode Character Conversion 5.Perform the PDF to DOC conversion at a very high speed 6.Allows user to convert entire document or only a specific page range 7.Converted files can be automatically opened immediately after conversion complete 8.Provides round the clock technical support 9. Preserve data structure, formatting and properties of content 10. This PDF to Word Converter is compatible with Microsoft Office 2010, 2007, and 2003.Pricing and Availability:Doremisoft PDF to Word converter is priced at $39.95 for single user license. You can downloaded online from Doremisoft pdf to word converter website
Sep 22, 2011 | Microsoft Office Professional 2007 Full...
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
I have a new iMac running OSX10.6.5 All of my saved Print Shop docs will not open. When I try to open them my computer opens my Adobe Photoshop Elements software and it says it can't read the doc. All my...
You have to change the file associations for them to open with Print Shop. Select any Print Shop document, right click and select Get Info. Under the section Open with, there is a dropdown menu that shows the programs that open that file type. Simply select Print Shop and click Change All... button. Click Continue at the prompt and Print Shop should open all those file types.
Nov 17, 2010 | Computers & Internet
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
Canon PIXMA MP780 All-In-One InkJet Printer Problem and credit card payment already submitted on canon pixma Please advise. Problem with fax memory, can't print faxes
1 Press [FAX], then press [Menu].
2 Use [< ] or [> ] to select <MEMORY REFERENCE>.
3 Press [OK].
4 Use [< ] or [> ] to select <PRINT DOCUMENT> or <DELETE DOCUMENT>.
▼ If you select <PRINT DOCUMENT>:
1. Press [OK]. 2. Use [<] or [> ] to select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the Numeric Keys. If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".)
3. Press [OK]. 4. Press [< ] to print the first page only, or press [> ] to print all pages of the document. 5. To print another document, return to branch-step 2, or to finish printing, go to step 6. ▼ If you select <DELETE DOCUMENT>:
1. Press [OK]. 2. Use [< ] or [> ] to select <ALL PRINTED DOCS.> or <1 DOCUMENT>. – <ALL PRINTED DOCS.>: Deletes all the printed documents stored in memory.
– <1 DOCUMENT>: Deletes a single document stored in memory.
3. Go to step 5. 5 Press [OK].
▼ If you selected <ALL PRINTED DOCS.> above:
1. Press [< ]. Press [> ] to cancel deleting, and the machine returns to the standby mode.
If you selected <1 DOCUMENT> above:
1. Use [< ] or [> ] to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the Numeric Keys. If you are unsure of the transaction number, print the DOC. MEMORY LIST. (See "Printing A List Of Documents In Memory".)
2. Press [OK]. 3. Press [< ]. Press [>] to cancel deleting, and the machine returns to the LCD of branch-step 1.
4. To delete another document, return to branch-step 1, or to finish deleting, go to step 6. 6 Press [Stop/Reset].
Sep 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do I print off a copy of the desk top?
Hi there.
Hit Prt Scr on the top right hand side of the keyboard, open paint and paste the screen shot in there, the click file and save as, save the file to your desktop or documents, then open the saved paint file and you should be able to print it off.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Microsoft DA900013 Keyboard
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Having trouble printing a document file in word
Check page setup and ensure page size for document same as page size for printer.
Check printer not set to only print current page.
Feb 07, 2008 | Lexmark X5470 All-In-One InkJet Printer
Adobe Photoshop Elements 5.0
When you zoom in most any photo editing program, all you do is change the appearance of the picture on your screen; nothing happens to the file, merely the size of the image you are viewing. To change the size for the file, here are detailed instructions:
  • Step 1. Select the command Resize - Image Size from the menu Image of Adobe Photoshop Elements. change-print-size-adobe.gif
  • Step 2. Activate the check-box Constrain Proportions to keep the image proportions.
  • Step 3. Activate the check-box Resample Image, if you want to keep the image resolution.
  • Step 4. Select the interpolation method: Nearest Neighbour, Bilinear or Bicubic. We recommend the Bicubic method of interpolation.
  • Step 5. In the group Document Size select units and enter new values in the fields Width and Height. If the check-box Resample Image is not activated, the resolution will change.
  • Step 6. Select OK
Dec 24, 2007 | Adobe Photoshop 7.0 for PC
Dell 968 All-In-One Printer Logo
47 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
