Question about Craftsman Saws
I have an 80" blade
  • 32 Answers
I have the Craftsman model 113 80" saw and ran into the same type of problem here's what I did.
-Take off motor,loosen set screw on pulley and push pully as far as it will go towards motor,The pulley has a internal shoulder that will position the pulley the correct distance on the motor shaft.
- put motor back on saw (This next part is VERY important) the motor has 4 studs,3 of them have sleeves,these sleeves make it so that when they are tightened down the motor can stilll move(do not over tighten ). The forth stud is the one with the wing nut adjustment,the wing nut is how you adjust the tension.once you have your tension set you tighten the bolt on this stud and it holds the motor in place.
-Now with the motor in place ( no belt on yet) lay a flat ruler from the drive pulley to the pulley on the bottom wheel. most likely this pully will need to be adjusted in or out. These pulleys must line up perfectly with each other and over time one or the other has moved.
Take motor back off and put on belt. replace motor.
Note** you cannot eyeball the two pulleys a flat square or ruller must be used.
Since I aligned mine I have had zero problems and it runs alot smoother.
I hope this helps you out.
Posted on Nov 15, 2010
Get a 12 "Sears craftsman band saw blade model no 113.279521c
I'm using Haltbar band saw blades that I got from sawblade.com . They have great quality band saw blades. I ordered 10 blades from them last month and shipping was free.
Oct 18, 2014 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
Manual 1987
In my search, this is the closest band saw to 11.324200 that have almost the same structures and features. 113.24201 band saw . You can download the manual from there. If you need a blade, I recommend you to visit sawblade.com , they custom made blades, I ordered my blades from them .
Dec 22, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I have Sears- Craftsman 10" band saw #113.244510. after installing new tire the blade tracks to the rear. Have followed manual but cannot solve proble- any suggestions?
Check this blog first. Are you installing a new blade? If the blade is running backwards, you just have to reverse it, turn inside out. Try watching the Alex Snodgrass' Youtube video Band Saw Tune Up .
Oct 17, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
How long is the band saw blade on model 113.24330C
I can't find a Sears model 113.24330C but there is a 113.243300 so hopfully part of the last 0 got worn off. That model is a 12" bench top band saw that uses a 1/4 X 80-inch blade.
Mar 19, 2012 | Craftsman Saws
My band saw (craftsman 12" tilt head) stopped
Hello'
I have the exact same saw. It sounds like the key stock came out of the pulley attached to the lower wheel. I will give you a quick rundown.
-unplug saw
-you will have to lay the saw on its side so you can remove the motor and drive belt.
-there are 2 seperate pulleys , the one connected to the motor and the one connected to the bottom wheel.
-loosen motor nuts and remove motor, pay close attention when removing motor 3 of the 4 studs have sleeve like spacers.
-once motor and belt are out of the way check the pulley on the bottom wheel,my guess is that the key stock came out and the pulley spins freely.
-loosen set screw,replace keystock and tighten.
-NOTE the keystock may have came out of the motor pully instead,check.
Now this next part is real important.
-once you get it figured out and are ready to put everything back together the 2 pulleys must be perfectly lined up, use a flat ruler, using your eye will not work.line the drive pulley up with the lower pulley. ( the pulley on the motor has a shoulder on it so when it is pushed towards motor it will be set in the right spot) .
It is either the pulley on the motor or the wheel that has lost its keystock.
It should be a easy fix,Good luck
Nov 05, 2010 | Craftsman 12 Tilt Head Band Saw Owner...
I have an old Sears Craftsman 7" Electric Handsaw model #315.27782. The blade I use for fine sawing has begun to wobble. I've taken it off, put it back on and tightened it several times. Same wobble. ...
It could be that the bearings that support the shaft that holds the blade are worn, allowing the shaft to move slightly and make the blade wobble. As the machine is an older model, I would try replacing the bearings.
Sep 16, 2010 | Craftsman Saws
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Blade does not track properly causes "tires" on drivewheels to come off making blade wobble.
Depending on the make and model of the bandsaw there should be tracking adjustment handwheels to get the bands to run center. If you have already done this, then inspect the drive wheel and the idler for being slightly bent, and or bearing/shaft failure.
Jan 04, 2010 | Ridgid 14" Band Saw with Stand
Saws Logo
113 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
