Question about Yamaha Electrical Supplies
Yamaha 5700 manual start gen. Pulls but will not start, fresh oil. And I"m at 5600 feet. And outside temp. Is about 38 degrees.
    Problem Solver:
  • 4 Answers
What have you tried so far? An engine needs fuel, air and spark to work properly.
Fuel - Has the generator been sitting for more than a couple of months? There could be bad gas in it, and/or varnish built up inside somewhere in the fuel tank/lines. The carburetor could be plugged somewhere blocking proper fuel delivery.
Air - The choke may not be working/applied properly, or the air filter clogged.
Spark - The spark plug could be fouled, have you tried seeing if there is spark or not? Is the spark plug wire on tight, is it the correct one, is it clean and gapped properly, etc?
Posted on Nov 13, 2010
What is the correct fridge temperature this fridge should be on?
If your refrigerator has 2 controls, the start setting is usually at mid point on both dials. That should give you a freezer temp close to 0 and a fresh food temp of 38 to 42 degrees. If only one control---same middle setting should produce about the same inside temps. Fresh food temp is best measures if you can put thermometer in a glass of water to stabilize the temp.
Apr 15, 2015 | Refrigerators
Need operator manual
From what I understand, the AVR-5600 owner's manual was never released in a PDF format since it was a 1998 model. However, the AVR 5700 manual is apparently a close match to the receiver. You can download the AVR 5700 manual here: Home Stereo System and Headphone Spec Sheet Downloads Denon
May 13, 2014 | Denon AVR-5600 Receiver
When temp get below 50 degree it die when shifting
Hi, Scott you may need to let it warm up longer or cover your oil cooler if you have one, for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
2003 Yamaha Star 1100 Classic Back to 2003 Yamaha Motorcycle Index Page
Tips Tricks
Dec 28, 2013 | 2003 Yamaha V Star 1100 Classic
1987 yamaha bw350 oil amount
1987-88 Yamaha BW350T & E's:
Using engine number 2JN-000101 / JYA2JN00( )HC000101
1600cc or 1.7qt
Use 20W40 SE for outside temps above 40*F degrees
Use SAE10W30 SE for Temps below 60*F degrees per Yamaha Manual
Oil Filter: 4X7-13440-90-00 (Original Part Number) or CH6005
Jan 31, 2013 | Yamaha FZ 750 MG (Europe-US Motorcycles
My Yamaha MT-01 is emitting warning light code 38
Hi, Najaf for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha MT Owners Club
Yamaha Fault Codes
Yamaha MT 01 Service Manual
YAMAHA MT 01 Owner Manual
Oct 13, 2012 | 2008 Yamaha MT-01
98 BUICK REGAL GS AC compressor will not come on. It has the climate control unit. All the lights and fans work and there is enought freon. The display reads -38 degrees for the outside temp. Would this...
If the outside temp.sensor is reading -38 degrees then this is what is causing the compressor not to come on.You need to check the wiring to the outside temp.sensor and the sensor.Make sure it is connected.It is located on the front grill area.Between the grill and the bumper cover.Hope this helps.Good luck.
May 19, 2010 | 1998 Buick Regal
Temperature control sensor?
Sounds like a loose connection -38 is probably the open circuit position. Not sure where the sensor would be though.
Jul 20, 2009 | 2006 Chevrolet Monte Carlo
Yamaha r6 doesnt start at 40 degrees, any help?
your oil is to thick the same happend to my buell, it start and stall about 5 times befor it would stay running. around 45 degrees outside,I switched to a thinner oil for winter. now it starts and rides in 10 degrees.
Jan 08, 2009 | 2005 Kymco Xciting 500
SHARP FO-5600 - THE MACHINE HAS AN ERROR MESSAGE IN THE DISPLAY AREA "CLEAR TONER COUNTER". I CANNOT FIND ANYTHING IN THE MANUAL ABOUT THIS MESSAGE
CDURHAM,
I found the answer to this on page 22 of the PDF manual that can be downloaded from http://www.sharpusa.com/files/fax_man_5700.pdf.
May 06, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Electrical Supplies Logo
177 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
