Question about Refrigerators
KitchenAid Model KSRG25FTSS00 dispenser motor runs good without ice in the tray but cannot turn when a few ice is in it. It only makes noise when the lever is pressed. Does the motor get weak after a few years of use? Another KitchenAid of same model does not make ice. 115V AC is detected at the wire connector on the ice maker but only 61V AC is at the test points T and H. Is that low voltage at T and H normal or it is due to some problem in the ice maker module? Thank you very much in advance! Juan
    President:
  • 1,891 Answers
Look for a damaged drive between the motor and the augar . very common . it is not the amount of ice but as it has to work harder with ice whan with no ice . drive is probably striped .. .. mm other peroblem not making ice is # 1 did the water fill the tray and did it freez and not harvest . these are twoo different problems and do not relate . ck the temp it must be 15 deg or lower .. for ice mker to work .. mm
Posted on Nov 10, 2010
I have a ge adora fridge that when pressing the lever for ice makes a loud humming noise & feels like freezer wants to explode. Cab anyone tell me if they have ever run into this issue
You probably have a ice dam in your ice tray. The anger is trying to dispense if but if the cubes have frozen together and produced a large chunk of ice it cannot break up. Open the freezer door completely and lift up and pull out through ice tray. Remove ice until dam removed. Reassert tray and make sure to turn ice maker back on. It is essy to inadvertently bump switch. Try dispensing ice to see. If noise went away.
Hope this helped!
Apr 19, 2016 | GE Refrigerators
Kitchenaid KSRS25 Ice dispenser blades get stuck
Greetings,
In looking up this partial model # KSRS25, it shows you have
the model with the large ice bin inside the freezer.
My question to you is: Does the auger motor run when you
push the ice lever?
2 trouble prone parts on this model. Both in the case of NO
auger motor activation.
#1 broken pin that hold the micro-switch on to the switch bracket.
Item # 15
1690545?addlogo=false
Next #2 and the Worst, A Broken Blue wire or wires in the wire loom
under the freezer door hinge. Un-repairable new door needed if still
available.. You have to get creative restoring the power.
So before I continue, Does the Auger motor Run?
And if it does, remove the bin and close the door switch that turns the
light off, and tape switch shut. With door open and ice cradle pushed
in watch the auger drive fork turn? Is the the key hole stripped in the
fork.(rounded out) May need the fork or motor. #9 & #2
1708855?addlogo=false
May 28, 2013 | KitchenAid Architect® Series II KSRS25RS
Dispenser wont dispense ice but water works whirlpool model
hi Charles.im assuming that is making ice but not releasing through the dispenser.many reasons but try these first 1-check ice bucket for frozen chunks of ice.if so empty and try.should make a noise of the motor turning.if yes put fresh ice and try.if no joy then needs further checks.could be motor ,pcb or micro swith.good luck Ali
Aug 23, 2012 | Refrigerators
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
I have a kitchenaid refrigerator KSRP25FNSS the
HI,
I am assuming that the problem is with dispensing ice only, is the water portion of the dispenser still working? Are the switches in the dispenser making contact, I have seen in some model as yours that the dispenser switch bracket broken and would not make contact with the arms when attempting to dispense. Last question, is the bar to the motor you replaced connected properly? I have seen the service motor have a deep well in it and not make contact with the bin as it rotates.
I hope this helps.
Aug 03, 2011 | KitchenAid KSRP25FNSS Side by Side...
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Jan 22, 2011 | KitchenAid KSRS25IL Side by Side...
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool ed5gvexvdoo side by side When using the ice dispenser (cubed or crushed) it will not dispense. I have pulled the ice tray and the motor for running the dispenser arm runs. I have emptied the tray...
this maybe a problem with you auger motor may be stripped.open the door remove the ice bin.then hold the metal u shape auger arm and try to turn it by hand or have some one try to dispence ice if the u shape braket turn easy ny hand or if it stops turning when being held replace the auger motor.i hope this is some help,good luck you may also have to replaced the ice bin.
Jan 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge side by side refrigerator model tfx20jrx ice wont dispense
If the auger will move freely with ice out of the pan then the auger motor may be defective. Sometimes the connection in the door switch is defective. When the door is closed the switch turns the circuit on to the auger and control panel. Because the auger uses more amps that the water dispenser the door switch may be the problem or auger motor is just worn out.
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Dispenser does not work.
Remove the ice tray and clean it throughly with warm water. Let it dry at room temperature and see what happens.
Jul 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
