I had to bring a computer home from our office where it was connected to a network. I am trying to install the printer CD for the HP LaserJet 3055 printer and at some point in the process, I get the following error related to the S: drive. The S: drive was on the network server at the office and this CD is apparently referencing it for some reason and generating the error message because there is no S: drive at home. MSI.Scan Box - Fatal error during installation. Error 1327: Invalid Drive: S:\ Is there a quick fix that I can turn something on or off so the S? drive is no longer related to this computer? There was a DOS command string that ran at startup and did something in reference to the network drives, maybe connects the local computer to the network server, that maybe is still trying to run but is not successful. Maybe it is causing this error message. If so, how do I stop that from running at startup? Any thoughts? Kim M. Rudisill
    Guru:
  • 610 Answers
Go to START >>> RUN then type msconfig..(click on OK). It should bring up System Configuration window. Go to STARTUP tab then un-tick the entry you think is the DOS Command String. This should disable it from running during startup. Restart the computer.
Posted on Nov 10, 2010
    Problem Solver:
  • 18 Answers
THis issue can be resolved. Just follow the instructions on this page..
http://www.out-of-warranty.com/invalid-drive-when-installing-hp/
Posted on Dec 08, 2010
How do I fix HP LaserJet 3055 always "offline"?
How do you have it connected? Click the search icon in the lower left and type DEVMGMT.MSC and hit enter. This brings up the device manager, look on the list for the printer and see if there are any ! ? or X next to it and let me know.
Aug 05, 2017 | HP Office Equipment & Supplies
HOW TO CONFIGURE LASERJET 3055
USB: Run the cd, when its asked for connecting connect the usb cable, do rest..Network. Menu>network setup>TCP/IP>enter IP address>save it.connect network patch cable, take configuration page through printer menu settings, verify the IP address save or not> go to system 1. Run the CD select network as network printer> system will detect the printer go for rest of the process..
2. Through system> start> settings>printers& faxes>add printer wizard > select as local printer> select create new port in dialog box> select TCP/IP> type configured IPadress> do rest of the run process..
Jul 11, 2012 | HP LaserJet 3055 All-In-One Printer
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 scan over network. How does one set the Laserjet 3055 up to scan over the network? I'm running XP professional.I set the printer up through Control panel - printer and faxes - Add a...
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
Jun 29, 2009 | HP LaserJet 3055 All-In-One Printer
Scanning from the network
Dear Friend,
Install the printer driver on your computer and than download fix scan utility from Hp.com. After installing fix scan utility You will be able to scan.
You have to do the same on every computer from where you want to scan.
Regard
Under Trainee
Dec 17, 2008 | HP LaserJet 3055 All-In-One Printer
HP laserjet 3055 all in one Scan problem
which OS are u using ?
try uninstall and reinstall the driver from the cd itself
Oct 31, 2008 | HP LaserJet 3055 All-In-One Printer
Envelope Formating Using Word 2003 & HP Laserjet 3055
The problem occurred when I used network but not direct connection. It turned out I had the wrong driver for the network connection. I learned this through HP's online troubleshooting tool.
Sep 30, 2008 | HP LaserJet 3055 All-In-One Printer
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
How to install Hp laserjet 3055
If the connection is ethernet. Print configuration from Printer.
Manually install printer.
Select computer is on local port
Local port to select is TCP/IP
then type in the network address to the printer.
Driver will still be inside computer.
Mar 03, 2008 | HP LaserJet 3055 All-In-One Printer
HP laserJet 3055 network connection
HOW TO CONNECT HP 3055 TO ROUTER/WIRELESS NETWORK. WINDOWS XP/WINDOWS VISTA.
I have just finished successfully connecting my HP 3055 to my router and using it over wireless on 2 computers, one with windows XP SP2 and one with VISTA.
INSTRUCTIONS FOR CONNECTING HP 3055 ON XP:
FIRST CONNECT THE PRINTER TO THE ROUTER WITH A ETHERNET CABLE. FIND OUT THE IP ADDRESS OF YOUR PRINTER. By me it was 192.168.0.66
Go to CONTROL PANEL and open "PRINTERS AND FAXES". on the top left choose "ADD A PRINTER" click "NEXT".
In the "LOCAL OR NETWORK PRINTER" window, choose "LOCAL PRINTER ATTACHED TO THIS COMPUTER" and uncheck "AUTOMATICALLY DETECT"... click "NEXT".
In the "SELECT A PRINTER PORT" window click the radio button "CREATE A NEW PORT", click the down arrow and choose "STANDARD TCP/IP PORT".
In the window that pops up click "NEXT"
In the ADD PORT window, where it says "PRINTER NAME OR IP ADDRESS, type in your printers IP address, by me it was 192.168.0.66. The bottom line will fill in automatically. Click "NEXT".
In the "INSTALL PRINTER SOFTWARE" window, if you have the disk just choose "HAVE DISK" and install from there. If not, in the left column choose "HP" and in the right column choose "HP LASERJET 3050" (by me it showed up in the list, you can download the driver from here http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1140780&prodTypeId=18972&prodSeriesId=1161389&swLang=8&taskId=135&swEnvOID=228
click "NEXT"
In the "NAME YOUR PRINTER" window, choose a name and also choose if you want to set it as the default printer (recommended) Click "NEXT"
In the next window choose whether or not you want to share the printer, and if you do assign a printer name. Click NEXT. The next window is optional if you want to make a name, you can just click NEXT and your done! Print a test page to make sure that all is fine.
Feb 11, 2008 | HP LaserJet 3055 All-In-One Printer
392 people viewed this question
k24674
Marvin
Marvin
