Question about Pentair 1.0 Hp Whisperflo Pump
HOW MANY dBA for the whisperflo pumps 230 volts
Wiring line side of 230v two speed pool pump. It has line 1-4 which do I use
There should be a schematic on that motor describing how to connect the power. You would definitely want to use 230 volts as this allows the motor to run more efficiently.
A thumbs up would be greatly appreciated if this answer is helpful to your free Fixya question.
Apr 12, 2014 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Wiring a single speed 230v 5hp ao smith pump: what wire goes to terminal B, L1, L2, A
L1 and L2 are the posts to hook up to, there is no polarity so either way works,
Oct 06, 2013 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
110 volt
see side of motor for schematic take off back either turn knob to 110 volts or you have to switch the brown wire to a different lug and the white wire to lug #2 then the black or colored wire goes to #1 and white goes to #2 green to ground
Jul 25, 2013 | Pentair Whisperflo 3/4 Hp 115/230v
Wiring
see side of motor it will show you wires to move then hook up for 120 volt
Wiring a 230/115 1 hp 56y pool pump motor
please verify the name plate to be 115 230 volt motor.there will be a schematic that shows you exactly how to hook up this motor depending on the voltage being supplied to it. The main thing is switching between 115 and 230 volts this is a selector switch this very easily forgotten about. Please make sure to check that and double check that to make sure its on the proper selected switch. Good luck
Jun 30, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
My new AO Smith motor does not have an L1 IT has L2, L3, and L4 so how do I hook the wires?
There is a schematic on the motor itself to show you exactly how to hook it up. The main thing is knowing whether it's 115 volt or 230 volt connection. Good luck any questions hit me back up.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Apr 26, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
I have a 1 hp whisperflo pump for my pool it is exactly two years old I came home to find out that the pump was not on. The pump was warm to the touch I checked all the breakers to no avail the pump never...
You would need to use a meter to make certain you are getting 230 volts all the way to the terminals on the back of the motor. If you are, you most likely have a defective motor, or at the least a blown or open motor start capacitor on the motor. All of these motors also have a thermal switch that shut off the motor when it gets to hot, then it will cool down, you will hear a click, and it will run again for a short period of time. This is caused by a broken cooling fan inside the motor, or dirt or leaves blocking the vent holes on the bottom of the motor.
Sep 02, 2011 | Pentair 011486 WhisperFlo High Performance...
Changing from 115 to 230 volts how to do it.
0
Usually - depends on the type of wire originally installed. Almost all of it is going to be rated 300V or more and if yours is then yes, change the breaker to a 2-pole and swap out any other devices in the circuit to be rated 230 and change the voltage selector on the pump motor to 230 and you are good to go. Examine the markings on your wire insulation to find the voltage ratings.
May 10, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Pentair 1.0 Hp Whisperflo Pump Logo
42 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
