Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Speaker Replacement I got a Supreme 4X12 Cabinet that has a blown speaker and just purchased a 12" texas heat to replace it. What would be the best way to do this.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
My friend first you have to consider these [a] check weather the amplifier has no ploblem [b] the output of your device in watts and ohms
note:some amplifiers are protected with a fuse between the amplifier and speaker
if the amplifier is still working make sure that the new speaker[12texasheat] output in watts matches with Supreme 4X12 Cabinet output.
Posted on Jul 16, 2008
Need to know how to wire a marshell speaker cab
here you go.
http://www.jumbosunshade.com/swd01.htm
make sure to figure out what the ohms are of each speaker and how it is currently wired before messing with it. Make a plan, then act.
Jan 29, 2014 | Marshall Amplification Marshall MG412A or...
How do you connect a peavey 6505+ amp to a marshall 1960a cabinet?
On the back of your 6505 there are two jacks that are labeled speaker outputs. For mono function, use either one of those outputs and run a SPEAKER cable from your amp to one of the input jacks of your 1960a cabinet. I assume it is a 4X12 cabinet. Either input will work. Make sure you match the ohm selector on your 6505 (right next to the output jack, 4/8/or 16 ohms) to the ohm rating on your 1960 cabinet. It is likely labeled on the plate that houses the input jacks. You should be good to go. NOTE: Never turn your amp on unless it is hooked up to a speaker cabinet and never use instrument cable to hook your amp to your speaker cabinet. Bad for a nice tube amp like yours.
Rock on and hope it helps.
Dec 02, 2013 | Peavey Music
Manual pdf
Here is a useful link that will answer most questions about this case.
I think the Randall should be Series-Parallel wired for 8 ohms
Speaker Wiring Diagrams
Oct 27, 2013 | Randall RX412 4x12 Cabinet
I have a bx4500h and a ultra bass 115 cabinet. the head is fine, but the crossover? is bad in the cabinet. what can i do? can i just by pass the crossover and just use a 1/4" jack straight to the...
does the cab have a horn like the one in the photo if it does then you must think again.
you must try to get a replacement crossover or get a speaker geek to fix it for you its not so hard you can get the burnt out components fro radio shack / maplin so on. most of the blown components will show damage or smell like they are burnt because thats what they are.
the cross over plays a very important job in the fact that it filters of the top frequencies so you only get subs on the bottom 12's bass / mid on the top 12's and hi frequencies on the horn.
you will loose all the quality if you go direct and could easily blow things up especially the horn.
this speaker cab looks like a Kenny i had and when working then they are fantastic. i blow one of the sub 12's and the cross over survived so unplug the speakers and test them 1 by one with a little power from an amp and a small amp that does not matter if it gets damaged
Apr 11, 2011 | Behringer Ultrabass BB410 1200W Bass...
I have a set of teac speakers that are about 40 years old and I need to replace a woofer. I just do not know which one to buy. The speakers were bought in Germany, the model number is LS-80 and they have...
These sound like they a JBL speaker.
1. You will need the impedence and diameter spec and the Hz (hertz) specifications to get a replacement set.
you can call JBL Altec-Lansing is the company that manufacturer this series of speaker.\ On the back of you speaker cabinet should be a phone number to the company or check the user manual that you received with the speaker system and they should be able to give full information on how to replace the speaker in question or where to have it repaired.
The cabinet is glued together and will need a cabinet expert to disassemble.
Contact JBL for more information.
Mar 10, 2010 | Electronics - Others
My marshall cabinet has serial# 44439. Can you tell me what year it was manufactured?
Have a look at this web page:http://www.thegearpage.net/board/archive/index.php/t-275743.html Also this one:http://www.marshallforum.com/cabinets-speakers/1034-dating-marshall-4x12-cabinet-without-speaker-codes.html Hope this gives you some help.
Nov 01, 2009 | Marshall MG412A 120W 4x12 Guitar EXtension...
12 blown velly
If you have an HGS unit, the only source for a replacement speaker is Velodyne.
You will need to contact velodyne for the price.
Oct 28, 2009 | Velodyne HGS-12 Subwoofer
DAV-IS10 Speaker Blown
OK, Subwoofer model number is SA-WSIS10and you need middle speaker mounted on top under following part number..
1-826-658-11 LOUDSPEAKER (12 cm) (MIDDLE)
Available in Part Store.
Mar 23, 2009 | Sony DAV-IS10 System
Kef k160 sp3134 hi i was wondering if speaker parts canbe purchased for these. also i wastrying to figure out whether you access the speakers inside the cabinet. thecabinets are sowellmade it is not easy...
I have a good KEF K160 tower (one speaker) for sale. I purchased the pair and one had a blown woofer. After trying to replace/repair, I purchased a pair of KEF C40s and been happy ever since. The good K160 looks and sounds good. Grill and cabinet in good shape, both black finish. Other speaker cabinet is in poor condition. I'll sell the single (or both if you want to pay shipping) for $75. (Plus shipping, around $50 USA ground delivery) These are hard to find.
Jul 17, 2008 | Audio Players & Recorders
Car Audio & Video Logo
57 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
